Magic smoke from RAMPS October 01, 2016 04:26PM |
Re: Magic smoke from RAMPS October 01, 2016 07:20PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Magic smoke from RAMPS October 03, 2016 08:49AM |
Re: Magic smoke from RAMPS October 04, 2016 04:01AM |
Re: Magic smoke from RAMPS October 04, 2016 11:13AM |
i desoldered those terminals, but unfortunately foil on the board came loose.Quote
brupje
You need beefy headers for the heated bed connections. 10A is a lot of current. The cheaper RAMPS will use cheaper components, so you maybe you are better of removing the header and soldering the wires directly.
Agreed.Quote
Also make sure the bed movements do not propagate to the RAMPS, solder connections with repeated movement isn't great either.
