fan d9? ramps 1.4
February 08, 2013 10:15PM
i have tried to hook up my fan to the d9 on ramps 1.4 and sent the g code but nothing happens it will not turn on or off
Re: fan d9? ramps 1.4
February 09, 2013 04:44AM
Which firmware?
February 09, 2013 10:46AM
Which firmware, and is your firmware "motherboard" set to the correct value for extruder, bed, fan?
Also, one of my fans does not work if the wires are backwards (I would have assumed it would have just spun in the opposite direction). Try reversing the wires
February 13, 2013 04:23AM
"wont turn on or off"? So does that mean that it does start?
February 13, 2013 08:58PM
In Marlin (and probably many other firmwares) there are multiple settings for the "Motherboard" - aka the board you're using to drive everything.
RAMPS 1.4 can either be type 33 or type 34.
Type 33 has the following setup:
D10 = Extruder 0
D9 = Fan
D8 = Heated Bed
Type 34 has it differently:
D10 = Extruder 0
D9 = Extruder 1
D8 = Heated Bed
So if you're going to use a fan on D9, your Motherboard setting needs to be set to type 33.
Note: Yes, this means by default, you can't use fans on a dual extruder setup.
May 12, 2014 02:54PM
I know this is a little old, but I have a fan connected to D9, and there seems to be no power going to this port?
Have I blown a fuse somewhere?
Regards,
James Simpson
May 12, 2014 04:33PM
JamesSimpson
Does anything (besides the heated bed) work? If so, it's not the fuse. Check the connector and the mosfet if everything else works.
