As shipped it seems as if the ramps board can either support 1 extruder and 1 fan, or two extruders. What would be the easiest way to have dual extruders and yet still have at least 1 fan under gcode control?
My thought was to use the motherboard 34 standard config for the two hot ends, and then use one of the available PWM outputs from the arduino together with a small MOSFET circuit many of which can be found on thingiverse. To get the g code control, I'd probably hack the firmware to apply the M106/107 commands to my new pin instead of two the standard fan pin.
am I missing anything with this?
