RAMPS 1.4 doesn't stop heating up the hot end
Posted by Dayzz
March 26, 2014 05:05PM
Hi all.
I'm using Repetier host + firmware, RAMPS1.4 on Arduino Mega and a E3D hot end.
I have the problem that sometimes the hot end gets hotter and hotter. The temperature shown in Repetier is still plausible (e.g. 475°C) while the hot end stinks and filament gets burnt. The red lamp showing the heater power is continuously red. The print itself (I mean the steppers, communication etc.) is still running.
I would say that either there is an electrical issue with the MOSFET or the PID controller got hung up. Unfortunately I cannot really reproduce the problem. It occurs only from time to time. After a reset everything is fine again. But since this issue can burn down my house, I'm currently not very happy with my printer.
Does anyone know what the problem could be or how I should proceed to find the root cause?
Thanks in advance!
Bjoern
Re: RAMPS 1.4 doesn't stop heating up the hot end
March 26, 2014 05:49PM
What firmware are you using?
Most firmware has an option to turn off the extruder if the hot end gets too hot. A lot of people turn this off at the start when testing as it also affects things like not having a thermistor or thermocouple connected at all.
Check the signal on Arduino pin D10 to see if it is constantly on when this happens. If it is not, then you most likely have a bad MOSFET.
Q: Where did you get your board from, and what MOSFETs are on the board (Note: They may not all be the same time).
Note: Some vendors put a different MOSFET on the boards than the one in the schematic. In some cases they choose a suitable replacement (the design is old, that component is harder to get, and newer better components now exist), but sometimes the replacement they choose is not very good and can fail like this. If you buy a replacement MOSFET yourself, I recommend something like the IRLB8743 (also IRLU8743), which is used on many other RepRap electronics variants. Another similarly suited replacement is the FDP8870, which is still a better performer than the original MOSFETs, but slightly less capable as the IRLB8743.
