Ramps powered with only 1 PSU? August 23, 2014 11:15PM |
Re: Ramps powered with only 1 PSU? August 24, 2014 12:15AM |
Re: Ramps powered with only 1 PSU? August 24, 2014 06:29AM |
Re: Ramps powered with only 1 PSU? August 24, 2014 02:11PM |
Re: Ramps powered with only 1 PSU? August 25, 2014 01:26PM |
Re: Ramps powered with only 1 PSU? August 25, 2014 01:32PM |
Re: Ramps powered with only 1 PSU? August 25, 2014 01:36PM |
Re: Ramps powered with only 1 PSU? August 25, 2014 02:42PM |
Re: Ramps powered with only 1 PSU? August 25, 2014 03:22PM |
Re: Ramps powered with only 1 PSU? August 25, 2014 11:09PM |
Depends on how good your meter is and what resolution it's samplying frequency is. Cheaper meters can be all over the places and you may not be able to determine accurately what voltage things are running at if it's switching the power on and off faster than what the meter can handle. That is where an analog meter can be handy as the physical delay of the needle sweeping back down is a lot slower than what the power is being cycled so it as a bit of built in "averaging".Quote
jbernardis
I'm not sure, but I believe that a DC voltage here would show the average of all of those on/off values.
