Bed not heating up September 12, 2014 05:38PM |
Re: Bed not heating up September 12, 2014 06:07PM |
Re: Bed not heating up September 13, 2014 02:17AM |
plexer
I have a RAMPS 1.4 board coupled to a Taruino classic with marlin configured and uploaded.
I can read the temperature from the bed thermistor and if I warm that up with a lighter the temp increases however commanding the bed to heat up does nothing.
I have 12v going in to each power connector on the RAMPS board if I measure the voltage between each bed lead and ground I get 11v at each which doesn't seem right?
Thanks
Ben
Re: Bed not heating up September 13, 2014 03:57PM |
Re: Bed not heating up September 15, 2014 01:00PM |
The D8, D9, and D10 screw termals all always supply 12v to whatever they are powered. The negative lead that would normally be connected to ground passes through a MOSFET which acts as the switch. When the microcontroller pulls the particular pin high, it allows the current to flow through the mosfet to ground, completing the circhut. By pulsing it on quickly, it can control the temperature or fan speed.Quote
plexer
Re: Bed not heating up September 16, 2014 02:53AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Bed not heating up September 16, 2014 11:43AM |
A butane TORCH might reach 1500C. A bic style lighter is probably closer to half of that, and that's at it's hotest point. It's not advisable to hold a thermistor under a flame, but quickly passing it through a flame a few times to raise it isn't going to damage it.Quote
Dust
so you applied 2000C to a device that is rated for 300C?
I would be amazed if this thermistor is still ok.
Re: Bed not heating up October 09, 2014 12:13PM |
