Auto Bed level Issue! NEED Help March 08, 2015 12:39AM |
Re: Auto Bed level Issue! NEED Help March 08, 2015 01:26PM |
Re: Auto Bed level Issue! NEED Help March 09, 2015 09:46AM |
Re: Auto Bed level Issue! NEED Help March 09, 2015 11:39AM |
gnex16
Thanks for the reply!!
I am guessing the teeth could be worn out like you said. Have ordered a couple of new servos just to be on the safer side.
1) By the way i didnt get the last part where you say i need to plug it directly onto the control board!! Sorry for being a noob but which control board are you talking of ??
I am using a RAMPS 1.4 and arduino mega 2560!!
2) I have an other issue. Whenever my printer is online and i touch the nozzle to remove the filament, the servo arm moves a little bit and the printer gets disconnected!
Could it be a case of a Short??
Have attached pics of the wiring on my Ramps Board!!
By the way the tweezers are metallic :p
Please have a look and let me know!!!
Thanks Again!!
Re: Auto Bed level Issue! NEED Help March 10, 2015 11:01AM |
Re: Auto Bed level Issue! NEED Help March 10, 2015 02:58PM |
Re: Auto Bed level Issue! Almost done. Need a Little more Help :p March 11, 2015 01:11PM |
Re: Auto Bed level Issue! Almost done. Need a Little more Help :p March 12, 2015 01:52AM |
Re: Auto Bed level Issue! NEED Help March 18, 2015 09:39AM |
Re: Auto Bed level Issue! NEED Help March 18, 2015 12:38PM |
gnex16
HI,
Sorry for the late reply.
Was travelling the last few days so didnt have a chance to reply!!
By the way got everything to work to an extent.
Just trying out a couple of settings in slice3r.
Thanks a lot for your support so far.
I had another question for you.
Have you tried printing anything using supports generated by slicer??
Would be helpful if you can share any knowledge regarding supports as there are a couple of objects i need to print but cannot unless I use supports.
Also is there any way to view the generated supports before the print begins either on slice3r or any slicer for that matter or on pronterface??
Thanks!!
