Extruder Heater PID affects LED strip connected to 12V Aux March 15, 2015 09:55AM |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 16, 2015 05:24AM |
Admin Registered: 13 years ago Posts: 7,004 |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 16, 2015 09:37AM |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 16, 2015 12:06PM |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 16, 2015 06:24PM |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 17, 2015 05:00AM |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 17, 2015 09:43AM |
ATX power supplies aren't designed to react to current demands of the heated bed or extruder switching on and off rapidly. A computer may change it's needs, but it will usually be gradually and smoothed out by the mainboard voltage regulation. Our printers are pretty primitive and there isn't much smoothing out other than high demand - no demand.Quote
rocketwiz
I use an ATX power supply for the printer but it has worked fine so far without the customary load resistor. I might try it now to see if it will improve the voltage regulation
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 17, 2015 06:15PM |
Re: Extruder Heater PID affects LED strip connected to 12V Aux March 17, 2015 07:05PM |
rocketwiz
So do proper switchmode psu's (say those 12v 30A ones you see on ebay) have better regulation? If so I'd use them rather than another atx for the next printer.
