Stepper not running smoothly above 100mm/s April 16, 2015 06:04PM |
Re: Stepper not running smoothly above 100mm/s April 16, 2015 08:01PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Stepper not running smoothly above 100mm/s April 16, 2015 08:59PM |
nophead
If your acceleration multiplied by steps per mm is bigger than 2,000,000 you may be suffering from a bug in marlin that I just squashed. [github.com]
Re: Stepper not running smoothly above 100mm/s April 17, 2015 05:24AM |
Re: Stepper not running smoothly above 100mm/s April 17, 2015 12:48PM |
Re: Stepper not running smoothly above 100mm/s April 17, 2015 01:49PM |
Re: Stepper not running smoothly above 100mm/s April 17, 2015 03:19PM |
Re: Stepper not running smoothly above 100mm/s April 17, 2015 06:31PM |
nubby
Are you sure you have the jumpers set to 1/16th? The bottom pin is the only one closed? I had some problems with skipping and prints stopping and starting with 1/32 stepping, probably because of the Ramps 16Mhz clock.
Re: Stepper not running smoothly above 100mm/s April 17, 2015 06:42PM |
AndrewBCN
Did you try measuring the voltage at the 12V 5A connector on the RAMPS, and then right after the 5A polyfuse (right on its leg for example)?
Also, I must say that upon further testing and from what I am reading these days in various forum posts, I am beginning to think that the DRV8825 drivers do not behave very well when (mis)matched with certain steppers which otherwise have no problems being driven by A4988 drivers, so it could be that you are unlucky and have just such a mismatch.
Re: Stepper not running smoothly above 100mm/s April 18, 2015 08:18AM |
Re: Stepper not running smoothly above 100mm/s April 18, 2015 09:06AM |
Re: Stepper not running smoothly above 100mm/s April 18, 2015 06:11PM |
Re: Stepper not running smoothly above 100mm/s April 18, 2015 07:22PM |
Re: Stepper not running smoothly above 100mm/s April 19, 2015 05:22AM |
Re: Stepper not running smoothly above 100mm/s April 19, 2015 06:35AM |
