Mosfet controlled heatbed always on May 14, 2015 09:18AM |
Re: Mosfet controlled heatbed always on May 14, 2015 10:34AM |
Re: Mosfet controlled heatbed always on May 14, 2015 10:39AM |
Re: Mosfet controlled heatbed always on May 14, 2015 11:54AM |
cdru
D8+ is always on, which means your secondary MOSFET is also always on.
Re: Mosfet controlled heatbed always on May 14, 2015 12:12PM |
Re: Mosfet controlled heatbed always on May 14, 2015 01:57PM |
Do you have an abnormally large bed that you need heated? It sounds like you're making things a lot more complicated than what you need to. Just find a power supply large enough. ATX or an enclosed SMPS one, Amazon or eBay can get a serviceable one for not that much.Quote
Zeprazy
cdru, the problem is I don't have one power supply sufficent to power the whole bed so I try to use two less powerful which can both handle half of the bed (two different circuits). That's why I can't use the board mosfet as I need two separated switches. At first, I took a relay but I have to use pwm and the relay doesn't seem happy about it .
Would it be possible to use another pin of the board to send the pwm signal?
Re: Mosfet controlled heatbed always on May 15, 2015 06:19AM |
