RAMPS for 5V Stepper Motors? (MOD) May 29, 2015 09:15AM |
Re: RAMPS for 5V Stepper Motors? (MOD) May 29, 2015 09:56AM |
Re: RAMPS for 5V Stepper Motors? (MOD) May 29, 2015 10:33AM |
Re: RAMPS for 5V Stepper Motors? (MOD) May 29, 2015 12:31PM |
Re: RAMPS for 5V Stepper Motors? (MOD) May 29, 2015 01:44PM |
GrahamLeach
We have been using the pololu trim pots to limit the current going to the motors to help keep the heat down.
Re: RAMPS for 5V Stepper Motors? (MOD) May 30, 2015 03:42AM |
Re: RAMPS for 5V Stepper Motors? (MOD) June 01, 2015 02:15PM |
o_lampe
I have disassambled a few CD-Roms and 5.25 floppy drives myself, but never found stepper motors?
I found many steppers in old copymachines and laserprinters, but they usually can´t do microstepping.
Re: RAMPS for 5V Stepper Motors? (MOD) June 05, 2015 11:56PM |
Re: RAMPS for 5V Stepper Motors? (MOD) June 06, 2015 04:09AM |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: RAMPS for 5V Stepper Motors? (MOD) June 19, 2015 09:57PM |
Re: RAMPS for 5V Stepper Motors? (MOD) June 20, 2015 06:10AM |
Cefiar
@Wurstnase: That is fine with normal motors, but the motors in CD/DVD Roms and the like get VERY hot if you put too much voltage into them. They have very little thermal mass to absorb that heat, and they also have very little surface area to dissipate it. They're also designed specifically for running off a 5V source, so the coil voltage is even lower than you might be used to with standard size motors.
Re: RAMPS for 5V Stepper Motors? (MOD) June 21, 2015 03:30AM |
Re: RAMPS for 5V Stepper Motors? (MOD) June 21, 2015 05:12AM |
