Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 16, 2016 04:13PM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 16, 2016 06:11PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 16, 2016 06:34PM |
Dust
1) check you endstops status with M119 comand. when endstops are triggred you cant move -ve
2) as a guess I would say z max feed rate is probably to high
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 16, 2016 07:31PM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 16, 2016 10:18PM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 17, 2016 02:36AM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 17, 2016 03:30AM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 21, 2016 01:17PM |
SENT: M105 RECEIVED: ok T:23.1 /0.0 B:22.0 /0.0 @:0 B@:0 SENT: M104 S80 T0 RECEIVED: ok RECEIVED: Error:MINTEMP triggered, system stopped! Heater_ID: 0 RECEIVED: Error: Printer halted. kill() called!
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] December 27, 2016 03:46PM |
//These defines help to calibrate the AD595 sensor in case you get wrong temperature measurements. //The measured temperature is defined as "actualTemp = (measuredTemp * TEMP_SENSOR_AD595_GAIN) + TEMP_SENSOR_AD595_OFFSET" #define TEMP_SENSOR_AD595_OFFSET 0.0 #define TEMP_SENSOR_AD595_GAIN 0.1
//#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders //#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] January 23, 2017 10:34PM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] January 24, 2017 05:28AM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] January 24, 2017 08:23AM |
Re: Ramps 1.4 conversion of Makerbot 2X @ 24v - Newbie at Marlin [Warning - wall of text] January 24, 2017 03:05PM |
obewan
The main problem with using themocouples is that they output such small voltages( mV) this voltage is susceptable to interference from the
stepper motors and allso the PID used to heat the hot end.
