power for ramp v 1.4
January 19, 2017 02:27AM
can i supply 12v/25 amp for extruder hotend and 5v/45 amp for ramp power and stepper supply....or do i need more current
Edited 1 time(s). Last edit at 01/19/2017 02:28AM by chow_noi.
Re: power for ramp v 1.4
January 19, 2017 03:03AM
Extruder and steppers run on 12V. No need to supply 5V to Ramps, except you want to run 5V servos or graphic LCD. Then you have to remove "D1" on the Ramps board, too.
January 19, 2017 04:24AM
i am not using any lcd or servos right now....thanks for the help..and is 12 powering my Arduino or should i get separate power supply
Edited 1 time(s). Last edit at 01/19/2017 04:32AM by chow_noi.
January 19, 2017 06:12AM
The stepper motors needs 12v (even if they are 5v steppers) , so you need to supply 12v to the 12v 5amp plug, if you want a heated bed then you provide 12v to the 12v 11amp plugs
The mega also gets power 12v from the 12v 5amp plug as the steppers. You do not put anything in the DC jack.
ie
January 19, 2017 10:13AM
ok....i get it. thanks again..that was very helpful smiling smiley
January 19, 2017 12:20PM
my power supply is of 25 amp...is it good.?
January 19, 2017 08:22PM
Your 25 amp power supply should be fine.
You only need 16amps, current is pulled from the supply, so more current is fine It will only take what it needs.
Edited 1 time(s). Last edit at 01/19/2017 08:23PM by Dust.
January 20, 2017 08:51AM
very helpfull. #Dust
