Re: RAMPS with SD card support? July 25, 2011 03:26PM |
Re: RAMPS with SD card support? July 25, 2011 03:28PM |
Re: RAMPS with SD card support? July 25, 2011 05:26PM |
Re: RAMPS with SD card support? July 25, 2011 06:32PM |
Re: RAMPS with SD card support? July 25, 2011 07:58PM |
Re: RAMPS with SD card support? July 26, 2011 12:15AM |
Re: RAMPS with SD card support? July 26, 2011 09:17AM |
Re: RAMPS with SD card support? July 26, 2011 10:16AM |
Re: RAMPS with SD card support? July 26, 2011 11:00AM |
Re: RAMPS with SD card support? July 26, 2011 12:00PM |
Re: RAMPS with SD card support? July 26, 2011 12:44PM |
Re: RAMPS with SD card support? July 27, 2011 08:46AM |
Re: RAMPS with SD card support? August 07, 2011 02:36PM |
Re: RAMPS with SD card support? October 22, 2011 02:48AM |
Re: RAMPS with SD card support? October 22, 2011 03:46AM |
Re: RAMPS with SD card support? October 22, 2011 04:20AM |
Re: RAMPS with SD card support? October 22, 2011 04:27AM |
Re: RAMPS with SD card support? October 22, 2011 07:12AM |
Re: RAMPS with SD card support? October 22, 2011 12:07PM |
Re: RAMPS with SD card support? October 24, 2011 12:13PM |
Re: RAMPS with SD card support? October 24, 2011 12:29PM |
Re: RAMPS with SD card support? October 24, 2011 02:41PM |
Re: RAMPS with SD card support? October 24, 2011 06:41PM |
Re: RAMPS with SD card support? November 07, 2011 10:32PM |
Re: RAMPS with SD card support? November 21, 2013 04:05PM |
julianh72
I was struggling a bit to understand how to fit my SD RAMPS onto my RAMPS 1.4 - and then I realised the layout of the 1.4 board is subtly different to the 1.3. The photos on the Wiki [reprap.org] show the SD RAMPS lining up neatly with the corner of the RAMPS board. On RAMPS 1.4, the corresponding pin pads have been moved a bit closer to the corner of the board, so it looks a little bit different, because the SD RAMPS daughter-board hangs over the corner of the RAMPS 1.4 board a little bit. I took the liberty of editing the Wiki to add a photo for other 1.4 users who might be confused as to how to install their SD RAMPS.
While I was at it, I also added a note that you MUST install Diode D1 on the RAMPS board if you want to be able to print without being connected to your PC. I know (now!) that this is covered elsewhere in the documentation, but it took me a while to work out why I could load gcode files onto the SD Card (I am using Pronterface - works perfectly!), start printing from the SD Card - and then my printer would stop as soon as I pulled the USB cable out of my Arduino Mega. Doh!
More about running at higher voltages: [forums.reprap.org]Quote
http://arduino.cc/en/Main/arduinoBoardMega2560
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
Re: RAMPS with SD card support? November 23, 2013 11:21AM |
Re: RAMPS with SD card support? November 24, 2013 04:34AM |
Re: RAMPS with SD card support? November 24, 2013 11:05AM |
Re: RAMPS with SD card support? November 24, 2013 11:10AM |
Re: RAMPS with SD card support? November 24, 2013 07:08PM |
