Question about units May 29, 2017 11:25AM |
Re: Question about units May 29, 2017 01:18PM |
Re: Question about units May 29, 2017 06:41PM |
Re: Question about units May 30, 2017 01:40AM |
Re: Question about units May 30, 2017 01:00PM |
dc42
What I was trying to say is that your acceleration settings are probably not the cause of the problem. The more likely cause is that the high inductance and back emf of those motors require a higher drive voltage than 12V at the movement speed you are trying to achieve. The CNC machine probably used a lower movement speed and/or higher drive voltage.
But you can try reducing the acceleration settings anyway. For the X and Y axes of a Cartesian printer, values of 1000 to 3000 mm/sec^2 are commonly used.
Re: Question about units May 30, 2017 06:27PM |
