Thermocouple
August 14, 2011 09:28AM
Hi. I want to hook up a thermocouple to my ramps 1.3. I have a ad595 ready to wire up and notice it requires 5v, ground and signal. What would be best way to hook this up? I was thinking of wiring 5v to someplace on the board that has an open spot and the same with ground. Any recommendations? As for signal, I was thinking of using one of the available pins and changing pin config or would the thermistor signal be ok? Thanks for any advice.
Re: Thermocouple
August 14, 2011 07:52PM
Not sure if it helps you but i have a working thermocouple board based ont he maxim chip.
the sprinter firmware allready supports it so it makes it easy to run. I can post the details if you wish
Re: Thermocouple
August 15, 2011 08:35AM
If its not too much trouble, please detail how the thermocouple should be setup. Mainly the wiring. Thank you.
Re: Thermocouple
August 20, 2011 03:45AM
Hi!
I also have a nice AD595CQ all wired up and ready to be connected. The AD595 delivers an analog voltage proportional to the temperature, no SPI.
I've got a RAMPS 1.2 to connect them.
Checking the code in Tonokip/Sprinter, it seems it expects the AD595 to be connected to the same pins used for the thermistors.
But the thermistor circuit has already a dividing 4.7K resistance and a capacitor soldered in (from my previous use of thermistors). Are those of nature to influence the readings? Recommended practice: keep them? desolder them?
I think those points need to be documented in the wiki. Any hints most welcome!
Re: Thermocouple
August 20, 2011 05:37AM
Remove them and consider filtering the power to the AD595 as I did here. [hydraraptor.blogspot.com]
I don't have much luck with thermocouples, I prefer thermistors unless the temperature is too high.
Re: Thermocouple
August 21, 2011 02:15AM
Thank you Nophead, outstanding work on Thermocouples!
Given the need to desolder and the general uncertainties about thermocouples, I think I'm going to keep the two thermistor inputs as they are, and mod the code to use another (free) analogic input pin.
