Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 02. October 2016 13:37 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 42 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 02. October 2016 13:48 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 19 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 02. October 2016 14:04 |
//#define PIDTEMP #define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current #define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current #if ENABLED(PIDTEMP) //#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result. //#define PID_DEBUG // Sends debug data to the serial port. //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay //#define PID_PARAMS_PER_EXTRUDER // Uses separate PID parameters for each extruder (useful for mismatched extruders) // Set/get with gcode: M301 E[extruder number, 0-2] #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature // is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max. #define PID_INTEGRAL_DRIVE_MAX PID_MAX //limit for the integral term #define K1 0.95 //smoothing factor within the PID // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it // Ultimaker //#define DEFAULT_Kp 22.2 //#define DEFAULT_Ki 1.08 //#define DEFAULT_Kd 114 // My Settings #define DEFAULT_Kp 100.0 #define DEFAULT_Ki 2.00 #define DEFAULT_Kd 35.00 //Autotuning Ergebnisse //#define DEFAULT_Kp 13.76 //#define DEFAULT_Ki 0.69 //#define DEFAULT_Kd 69.00 // Mendel Parts V9 on 12V //#define DEFAULT_Kp 63.0 //#define DEFAULT_Ki 2.25 //#define DEFAULT_Kd 440 #endif // PIDTEMP
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 03. October 2016 03:39 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 03. October 2016 17:47 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 04. October 2016 02:13 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 590 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 04. October 2016 11:14 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 632 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 04. October 2016 18:18 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 05. October 2016 06:41 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 491 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 09. October 2016 13:13 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 10. October 2016 03:56 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 10. October 2016 12:59 |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 10. October 2016 16:40 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Temperatur kann beim Drucken nicht erreicht werden, davor aber schon 14. October 2016 07:32 |
