Marlin 1.1.0 RC7 Beeper ausschalten 12. November 2016 10:27 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 422 |
Re: Marlin 1.1.0 RC7 Beeper ausschalten 12. November 2016 11:37 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
Re: Marlin 1.1.0 RC7 Beeper ausschalten 13. November 2016 10:25 |
sketch\ultralcd.cpp: In function 'void lcd_quick_feedback()': ultralcd.cpp:2341: error: 'LCD_FEEDBACK_FREQUENCY_HZ' was not declared in this scope lcd_buzz(LCD_FEEDBACK_FREQUENCY_DURATION_MS, LCD_FEEDBACK_FREQUENCY_HZ); ^ exit status 1 'LCD_FEEDBACK_FREQUENCY_HZ' was not declared in this scope
//beeper #define BEEPER 37 //[RAMPS14-SMART-ADAPTER] / 37 = enabled; -1 = dissabled / (if you don't like the beep sound ;-)
Re: Marlin 1.1.0 RC7 Beeper ausschalten 13. November 2016 11:57 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: Marlin 1.1.0 RC7 Beeper ausschalten 14. November 2016 03:14 |
#if ENABLED(LCD_I2C_SAINSMART_YWROBOT) // This uses the LiquidCrystal_I2C library ( [bitbucket.org] ) // Make sure it is placed in the Arduino libraries directory. #define LCD_I2C_TYPE_PCF8575 #define LCD_I2C_ADDRESS 0x27 // I2C Address of the port expander #define ULTIPANEL #define NEWPANEL #endif // PANELOLU2 LCD with status LEDs, separate encoder and click inputs #if ENABLED(LCD_I2C_PANELOLU2) #define LCD_I2C_TYPE_MCP23017 #define LCD_I2C_ADDRESS 0x20 // I2C Address of the port expander // #define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD #ifndef ENCODER_PULSES_PER_STEP #define ENCODER_PULSES_PER_STEP 4 #endif #ifndef ENCODER_STEPS_PER_MENU_ITEM #define ENCODER_STEPS_PER_MENU_ITEM 1 #endif #define ULTIPANEL #define NEWPANEL #endif // Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs #if ENABLED(LCD_I2C_VIKI) // This uses the LiquidTWI2 library v1.2.3 or later ( [github.com] ) // Make sure the LiquidTWI2 directory is placed in the Arduino or Sketchbook libraries subdirectory. // Note: The pause/stop/resume LCD button pin should be connected to the Arduino // BTN_ENC pin (or set BTN_ENC to -1 if not used) #define LCD_I2C_TYPE_MCP23017 #define LCD_I2C_ADDRESS 0x20 // I2C Address of the port expander // #define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD (requires LiquidTWI2 v1.2.3 or later) #define ULTIPANEL #define NEWPANEL
Re: Marlin 1.1.0 RC7 Beeper ausschalten 14. November 2016 04:55 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
#undef BEEPER_PIN #define BEEPER_PIN -1
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Marlin 1.1.0 RC7 Beeper ausschalten 14. November 2016 11:38 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 648 |
Re: Marlin 1.1.0 RC7 Beeper ausschalten 14. November 2016 12:56 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 214 |
sechsteelement
ich verwende ein Ramps 1.4 mit einem Full Smart Graphic Controller und der Marlin 1.1.0 RC7 Firmware.
Ich möchte gerne den Beeper ausschalten........
Re: Marlin 1.1.0 RC7 Beeper ausschalten 14. November 2016 14:13 |
Re: Marlin 1.1.0 RC7 Beeper ausschalten 14. November 2016 14:59 |
sechsteelement
@ printey, ich habe schon mal versucht die Frequenzen auf 1 und 5 zu legen, damit der Ton dann tiefer sein müsste, bzw 1Hz würde man ja so nicht mehr hören können. Es hat aber keine Änderung im Ton gegeben.
Mit 0 habe ich es noch nicht ausprobiert, werde ich aber machen, da es sich kompilieren lässt ohne Fehlermeldung
Re: Marlin 1.1.0 RC7 Beeper ausschalten 15. November 2016 13:16 |
