[s] Marlin mit tmc 2208 für P3Steel Toolson 11. September 2019 09:05 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 45 |
Re: [s] Marlin mit tmc 2208 für P3Steel Toolson 11. September 2019 13:53 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 140 |
Re: [s] Marlin mit tmc 2208 für P3Steel Toolson 12. September 2019 05:07 |
Re: [s] Marlin mit tmc 2208 für P3Steel Toolson 29. October 2019 09:26 |
#define INVERT_X_DIR false #define INVERT_Y_DIR false
Re: [s] Marlin mit tmc 2208 für P3Steel Toolson 29. October 2019 09:35 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.891 |
#define X_HOME_DIR -1 #define Y_HOME_DIR 1 //-1
Re: [s] Marlin mit tmc 2208 für P3Steel Toolson 29. October 2019 10:10 |
In file included from sketch\MarlinConfig.h:42:0, from sketch\I2CPositionEncoder.cpp:31: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\malyanlcd.cpp:44: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\G26_Mesh_Validation_Tool.cpp:27: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\SdVolume.cpp:29: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\Marlin.h:35, from sketch\stepper_dac.cpp:44: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ exit status 1 In file included from sketch\MarlinConfig.h:42:0, from sketch\nozzle.cpp:23: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\neopixel.cpp:27: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\MarlinSerial.cpp:36: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\enum.h:26, from sketch\parser.h:32, from sketch\parser.cpp:27: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ In file included from sketch\MarlinConfig.h:42:0, from sketch\stepper_indirection.h:47, from sketch\stepper_indirection.cpp:34: SanityCheck.h:1280:8: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^ #error "Enable USE_XMAX_PLUG when homing X to MAX."
Re: [s] Marlin mit tmc 2208 für P3Steel Toolson 01. November 2019 10:46 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 300 |
// @section homing // Specify here all the endstop connectors that are connected to any endstop or probe. // Almost all printers will be using one per axis. Probes will use one or more of the // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG //#define USE_ZMAX_PLUG // Enable pullup for all endstops to prevent a floating state #define ENDSTOPPULLUPS #if DISABLED(ENDSTOPPULLUPS) // Disable ENDSTOPPULLUPS to set pullups individually //#define ENDSTOPPULLUP_XMAX //#define ENDSTOPPULLUP_YMAX //#define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #define ENDSTOPPULLUP_ZMIN_PROBE #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING true // Set to true to invert the logic of the probe. // Direction of endstops when homing; 1=MAX, -1=MIN // :[-1,1] #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
#define X_DRIVER_TYPE TMC2208_STANDALONE #define Y_DRIVER_TYPE TMC2208_STANDALONE #define Z_DRIVER_TYPE TMC2208_STANDALONE //#define X2_DRIVER_TYPE A4988 //#define Y2_DRIVER_TYPE A4988 //#define Z2_DRIVER_TYPE A4988 //#define Z3_DRIVER_TYPE A4988 #define E0_DRIVER_TYPE TMC2208_STANDALONE //#define E1_DRIVER_TYPE A4988 //#define E2_DRIVER_TYPE A4988 //#define E3_DRIVER_TYPE A4988 //#define E4_DRIVER_TYPE A4988 //#define E5_DRIVER_TYPE A4988
