Probleme mit Octoprint 09. December 2019 08:53 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 32 |
Re: Probleme mit Octoprint 11. December 2019 16:17 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 140 |
Re: Probleme mit Octoprint 12. December 2019 13:37 |
Changing monitoring state from "Operational" to "Starting" Send: N0 M110 N0*125 Recv: ok N:0 Send: N1 M117 ETA: -*98 Recv: ok N:1 Changing monitoring state from "Starting" to "Printing" Send: N2 M140 S55*87 Recv: ok N:2 Send: N3 M105*36 Recv: ok T:47 /0 B:39 /55 @:0 B@:0 Send: N4 M190 S55*92 Recv: wait Send: N5 M104 S210*99 Recv: T:47 E:0 B:39 Recv: T:47 E:0 B:39 Recv: wait Send: N6 M105*33 Recv: T:47 E:0 B:39 Recv: wait Send: N7 M105*32 Recv: T:47 E:0 B:39 Recv: T:47 E:0 B:39 Recv: wait Send: N8 M109 S210*99 Recv: T:47 E:0 B:39 Recv: T:47 E:0 B:39 Recv: wait Send: N9 M82*16 Recv: T:47 E:0 B:39 Recv: wait Send: N10 G28*34 Recv: T:47 E:0 B:39 Recv: T:47 E:0 B:40 Recv: wait Send: N11 G1 Z15.0 F6000*24 Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:40 Recv: wait Send: N12 M105*20 Recv: T:46 E:0 B:40 Recv: wait Send: N13 G92 E0*117 Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:40 Recv: wait Send: N14 M105*18 Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:40 Recv: wait Send: N15 G1 F200 E3*30 Recv: T:46 E:0 B:40 Recv: wait Send: N16 G92 E0*112 Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:41 Recv: wait Send: N17 M105*17 Recv: T:46 E:0 B:41 Recv: T:45 E:0 B:41 Recv: wait Send: N18 M92 E95.74*101 Recv: T:45 E:0 B:41 Recv: wait Send: N19 M105*31 Recv: T:45 E:0 B:41 Recv: T:45 E:0 B:41 Recv: wait Send: N20 G92 E0*117 Recv: T:45 E:0 B:41 Recv: T:45 E:0 B:41 Recv: wait Send: N21 G92 E0*116 Recv: T:45 E:0 B:41 Recv: wait Send: N22 M105*23 Recv: T:45 E:0 B:41 Recv: T:45 E:0 B:42 Recv: wait Send: N23 G1 F3600 E-2*0 Recv: T:45 E:0 B:42 Recv: T:45 E:0 B:42 Recv: wait Send: N24 M105*17 Recv: T:45 E:0 B:42 Recv: wait Send: N25 M107 P1*83 Recv: T:44 E:0 B:42 Recv: T:44 E:0 B:42 Recv: wait Send: N26 G0 F2400 X110.258 Y34.937 Z0.3*30 Recv: T:44 E:0 B:42 Recv: T:44 E:0 B:42 Senden
Re: Probleme mit Octoprint 12. December 2019 15:06 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.194 |
Wortmann30
Das war jetzt nur der Start aber wie geschrieben das Heizbett schaltet ein aber nicht das Hotend.
Bei dem Schnipsel oben habe ich nur gewartet bis das Heizbett ein paar Grad wärmer wurde dann habe ich abgebrochen.
Re: Probleme mit Octoprint 12. December 2019 17:54 |
Wie meinst du das genau ? Sendest du von Cura den GCode an Octoprint oder direkt an den Drucker ?
Bei Cura 4.4.0 kann man ja den Drucker verbinden, und wenn man das STL gesliced, hat kommt unten rechts im Bild ja das Fenster, mit der Möglichkeit die Datei auf der Festplatte oder wenn eine SD Karte eingelegt ist, auf dieser oder eben wenn ein Drucker online das File zu ihm zu senden.
Ich hoffe es ist klar was ich meine. Wenn ich eben diesen Gcode auf SD speichere und dann in den Drucker stecke und laufen lasse funktioniert alles.
Send: N2 M140 S55*87 => starte Bettheizung mit 55 Grad Solltemp ohne Warten Recv: ok N:2 => Zeile 2 von FW akzeptiert Send: N3 M105*36 => Ausgabe aktuelle Temp in Terminal, was er in der nächsten Zeile macht: Recv: ok T:47 /0 B:39 /55 @:0 B@:0 => HE = 47° Ohne geheitzt zu haben ? Bett = 39 ° ? Oder steht der Drucker in deiner Sauna oder im Backofen ;-) (sorry ...) ? => sehr suspekt ! Send: N4 M190 S55*92 => heize Bett auf 55° und warte bis erreicht sind Recv: wait wo bleibt das "ok" ? hier sollte Octoprint eigentlich erstmal warten, bevor weiterer GCode gesendet wird ... macht es aber nicht: Send: N5 M104 S210*99 => heize HE auf 210° auf, arbeite den GCode aber weiter ab Recv: T:47 E:0 B:39 => da stimmt was nicht! Die Betttemp ist reported bei 39°, sollte aber 55° sein! Recv: T:47 E:0 B:39 Recv: wait Send: N6 M105*33 => und noch einmal: Ausgabe aktuelle Temp in Terminal Recv: T:47 E:0 B:39 Recv: wait Send: N7 M105*32 Recv: T:47 E:0 B:39 Recv: T:47 E:0 B:39 Recv: wait Send: N8 M109 S210*99 => heize HE auf 210° und warte mit weiterer GCode-Ausführung, bis erreicht Recv: T:47 E:0 B:39 => da passiert aber nix - zumindest nichts in der Übertragung der Daten an Octoprint. Was steht denn jetzt aktuell in der Temp-Anzeige auf dem Touchscreen ? Recv: T:47 E:0 B:39 Recv: wait Send: N9 M82*16 => und mit dem Senden des GCodes wird auch nicht gewartet Recv: T:47 E:0 B:39 => aber das sind immer noch die gleichen Tempwerte! Obwohl er mit der Ausführung des weiteren GCode warten sollte bis die Solltemp erreicht ist Hier ist was faul! Recv: wait Send: N10 G28*34 => Home x,y,z Recv: T:47 E:0 B:39 Recv: T:47 E:0 B:40 Recv: wait Send: N11 G1 Z15.0 F6000*24 => Fahre Z auf 15 mm hoch (mit einer ziehmlichen Geschwindigkeit ...) Recv: T:46 E:0 B:40 => Bett gerade mal 40°, HE-Temp 46° Recv: T:46 E:0 B:40 Recv: wait Send: N12 M105*20 Recv: T:46 E:0 B:40 Recv: wait Send: N13 G92 E0*117 Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:40 Recv: wait Send: N14 M105*18 Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:40 Recv: wait Send: N15 G1 F200 E3*30 => fördere 3mm Filament - kalt? Recv: T:46 E:0 B:40 Recv: wait Send: N16 G92 E0*112 => setze Filament-Pos zurück auf Null Recv: T:46 E:0 B:40 Recv: T:46 E:0 B:41 Recv: wait Send: N17 M105*17 Recv: T:46 E:0 B:41 Recv: T:45 E:0 B:41 Recv: wait Send: N18 M92 E95.74*101 => hier wird für den Extruder die Steps per mm gesetzt (mach ich bei mir in der geflasheten FW, geht aber auch so, ist der Wert ok ?) Recv: T:45 E:0 B:41 Recv: wait Send: N19 M105*31 Recv: T:45 E:0 B:41 => das Bett ist hier gerade mal 2° wärmer :-( Recv: T:45 E:0 B:41 Recv: wait Send: N20 G92 E0*117 Recv: T:45 E:0 B:41 Recv: T:45 E:0 B:41 Recv: wait Send: N21 G92 E0*116 Recv: T:45 E:0 B:41 Recv: wait Send: N22 M105*23 Recv: T:45 E:0 B:41 Recv: T:45 E:0 B:42 Recv: wait Send: N23 G1 F3600 E-2*0 => Filament Retract um 2 mm Recv: T:45 E:0 B:42 Recv: T:45 E:0 B:42 Recv: wait Send: N24 M105*17 Recv: T:45 E:0 B:42 Recv: wait Send: N25 M107 P1*83 Recv: T:44 E:0 B:42 Recv: T:44 E:0 B:42 Recv: wait Send: N26 G0 F2400 X110.258 Y34.937 Z0.3*30 => anscheinend die Druck-Startposition, jetzt soll es losgehen, Temp stimmt aber nicht! ...
Was meinst du genau mit Firmware und Octoprint?
Da habe ich mal Marlin ein gestellt wenn ich mich recht erinnere.
Connecting to: /dev/ttyACM0 Changing monitoring state from "Offline" to "Opening serial port" Connected to: Serial(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Changing monitoring state from "Opening serial port" to "Connecting" Send: N0 M110 N0*125 Send: N0 M110 N0*125 Recv: echo:Unknown command: "��N0 M110 N0" Recv: ok Changing monitoring state from "Connecting" to "Operational" Send: N0 M110 N0*125 Recv: ok Recv: ok Send: N1 M115*39 Send: N2 M21*18 Recv: FIRMWARE_NAME:Marlin 1.1.9 (Github) SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPEOKJ-Printer V190520 EXTRUDER_COUNT:1 UUID:2782f3dc-6907-4bcb-ab25-51b0ba4c142f Recv: CapERIAL_XON_XOFF:0 Recv: Cap:EEPROM:1 Recv: Cap:VOLUMETRIC:1 Recv: Cap:AUTOREPORT_TEMP:1 Recv: CapROGRESS:0 Recv: CapRINT_JOB:1 Recv: Cap:AUTOLEVEL:0 Recv: Cap:Z_PROBE:0 Recv: Cap:LEVELING_DATA:0 Recv: Cap:BUILD_PERCENT:0 Recv: CapOFTWARE_POWER:0 Recv: Cap:TOGGLE_LIGHTS:0 Recv: Cap:CASE_LIGHT_BRIGHTNESS:0 Recv: Cap:EMERGENCY_PARSER:0 Recv: Cap:AUTOREPORT_SD_STATUS:0 Recv: Cap:THERMAL_PROTECTION:1 Recv: ok ... usw ...
Re: Probleme mit Octoprint 13. December 2019 05:13 |
Send: N18 M92 E95.74*101 => hier wird für den Extruder die Steps per mm gesetzt (mach ich bei mir in der geflasheten FW, geht aber auch so, ist der Wert ok ?)Die Werte hier sind korrekt, die habe ich in Cura in den Start Code genommen.
Connecting to: COM8 Changing monitoring state from "Offline" to "Opening serial port" Connected to: Serial(port='COM8', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Changing monitoring state from "Opening serial port" to "Connecting" Send: N0 M110 N0*125 Send: N0 M110 N0*125 Recv: ok N:0 Changing monitoring state from "Connecting" to "Operational" Send: N0 M110 N0*125 Recv: ok N:0 Recv: ok N:0 Send: N1 M115*39 Send: N2 M21*18 Recv: ok CBD make it.Dateec 10 2018 Time:15:12:35 Recv: //SD init fail! Recv: ok N:2
Re: Probleme mit Octoprint 15. December 2019 14:11 |
Wortmann30
Und du siehst das vollkommen richtig das Bett wird geheizt und dann war es das erst mal, auch kein Home wird gefahren. Octoprint sendet munter Daten weiter.
Man sieht auch schön das das Hotend angefordert wird zu heizen aber es tut sich nichts...
Und zur Firmware (M115) wird reichlich wenig ausgegeben ... kannst das ja mal gesondert über das terminal ausgeben und sehen, ob mehr kommt ...Quote
Zu dem Test, das ist dabei raus gekommen:
Was hier auch noch auffällt die SD karte lässt sich nicht initialisieren.
Das ist auch ein Problem aber ich dachte mal eines nach den anderen angehen.
Da könnte ich nur raten, aber es sind dann wohl auch 2 Extruder vorhanden ? Dann müssen auch zwei in Cura definiert werden, denn wie sonst willst du den Vorschub der beiden Filament-Stränge einzeln steuern. Wie das allerdings dann mit dem HE-Aufheizen geregelt ist kann ich leider nicht sagen. Hab kein Cyclops im Einsatz, da müssten sich andere Helfer melden. Das sollte aber nicht damit zu tun haben, dass Octoprint nicht wartet ...Quote
In Cura habe ich nur einen Extruder eingestellt, kann das der Fehler sein?
habe versuchsweise zwei HE eingestellt bringt aber auch keine Besserung...
Für das HE gibt´s nur einen Anschluss das HE mit zwei Druckköpfen die hier benutzt werden kann ein Cyclops-Hotend also.
Was ist eigentlich das für eine Einstellung?
[attachment 113651 Unbenannt.PNG]
Und wo kann man denn die Firmware umstellen? Finde irgendwie nichts.
Re: Probleme mit Octoprint 16. December 2019 06:02 |
Send: N13 M115*20 Recv: ok CBD make it.Dateec 10 2018 Time:15:12:35 [...]Wie du schon sagtes leider nicht viel...
Re: Probleme mit Octoprint 16. December 2019 17:21 |
Re: Probleme mit Octoprint 17. December 2019 04:10 |
cd ~/.octoprint/plugins wget [gist.githubusercontent.com] wget [gist.githubusercontent.com] sudo service octoprint restart
C:\>cd OctoPrint C:\OctoPrint>venv\Scripts\activate.bat (venv) C:\OctoPrint>aber das ging irgendwie auch nicht..., ich bekomme nur diese Ausgabe:
(venv) C:\OctoPrint>cd ~/.octoprint/plugins Das System kann den angegebenen Pfad nicht finden. (venv) C:\OctoPrint>wget [gist.githubusercontent.com] Der Befehl "wget" ist entweder falsch geschrieben oder konnte nicht gefunden werden. (venv) C:\OctoPrint>wget [gist.githubusercontent.com] Der Befehl "wget" ist entweder falsch geschrieben oder konnte nicht gefunden werden. (venv) C:\OctoPrint>sudo service octoprint restart Der Befehl "sudo" ist entweder falsch geschrieben oder konnte nicht gefunden werden. (venv) C:\OctoPrint>
Re: Probleme mit Octoprint 17. December 2019 09:00 |
Registrierungsdatum: 5 Jahre zuvor Beiträge: 143 |
Re: Probleme mit Octoprint 17. December 2019 09:58 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Entweder die Plugins von Hand dorthin kopieren oder vorher das hier installieren:Quote
docs.octoprint.org
For Linux that will be ~/.octoprint/plugins, for Windows it will be %APPDATA%/OctoPrint/plugins and for Mac ~/Library/Application Support/OctoPrint/plugins
Re: Probleme mit Octoprint 17. December 2019 14:13 |
Re: Probleme mit Octoprint 17. December 2019 14:14 |
Re: Probleme mit Octoprint 17. December 2019 14:22 |
Wortmann30
Jedoch bleibt auch bei mir zuhause noch ein kleines Problem, die SD Karte lässt sich nicht Initialisieren... Woran kann das liegen? Muss die gesondert formatiert werden?
Danke bisher für alle Hilfestellung!
Re: Probleme mit Octoprint 18. December 2019 11:06 |
Re: Probleme mit Octoprint 18. December 2019 16:18 |
Re: Probleme mit Octoprint 19. December 2019 03:34 |
Das funktioniert alles bestens.Quote
hotprinter
Ok, kannst du denn die SD-Karte entnehmen, über einen SD-Kartenleser von Windows aus mit GCode-Dateien bestücken, dann wieder in den Drucker einlegen und von dort mit dem Touch-Screen einen Druck von SD-Card anstoßen ?
Wird die SD-Karte ohne Octoprint vom Drucker erkannt, d.h. über den Touchscreen (in der Hoffnung, das dort SD-Karten-Funktionen auswählbar sind).
Wenn nicht: sind die SD-Kartenfunktionen von der Firmware unterstützt bzw auch aktiviert (muss man z.B. in Marlin extra aktivieren)
Mag sein aber so kann ich auch auf dem Display den Druck verfolgen, da ändert ich nichts wenn ich über Octoprint drucke.Quote
hotprinter
Das zweite ist dann die Ansteuerung der SD-Card von Octopint aus. Hab ich selbst nie richtig genutzt, da die Übertragung über Octoprint auf die SD-Card sehr langsam ist. Da geht's schneller, wie oben beschrieben. Ausserdem sehe ich keinen Vorteil, die Druckdaten erst via Octoprint auf die SD-Karte zu kopieren und dann über Octoprint zu drucken. Octoprint muss auch dafür die ganze Zeit laufen, d.h. man kann es gleich ohne SD-Card direkt über Octoprint drucken.
Re: Probleme mit Octoprint 19. December 2019 04:00 |
2019-12-19 09:58:45,918 - octoprint.printer.standard - ERROR - Exception while sending print progress to plugin octoprint_eta Traceback (most recent call last): File "c:\octoprint\venv\lib\site-packages\octoprint\printer\standard.py", line 236, in call_plugins plugin.on_print_progress(storage, filename, progress) File "c:\octoprint\venv\lib\site-packages\octoprint_eta\__init__.py", line 42, in on_print_progress self.eta_string = self.calculate_ETA() File "c:\octoprint\venv\lib\site-packages\octoprint_eta\__init__.py", line 30, in calculate_ETA strtime = format_time(finish_time) File "c:\octoprint\venv\lib\site-packages\babel\dates.py", line 800, in format_time format = get_time_format(format, locale=locale) File "c:\octoprint\venv\lib\site-packages\babel\dates.py", line 411, in get_time_format return Locale.parse(locale).time_formats[format] AttributeError: 'NoneType' object has no attribute 'time_formats'
Re: Probleme mit Octoprint 19. December 2019 16:24 |
Das wäre für mich der einzige Grund.
Oder gibt es da ne Möglichkeit die Daten auch auf dem Touch Screen darzustellen?
Re: Probleme mit Octoprint 20. December 2019 06:48 |
Da habeich eben nichts gefunden, bzw denke ich das ich das richtig eingestellt habe, also er hat den aktuellen API code in der App...Quote
hotprinter
Octoprint-Meldungen in der App:
Hast du in Octoprint Einstellungen vorgenommen, das es Infos über das Internet freigibt ? Ggf auf einem erreichbaren Server ? Dann könnte deine App diese - je nach Einstellung - auch über das Inet abrufen. Aber mehr kann ich dir darüber nicht sagen. Ist a) "angebissenes Obst" ;-) und b) hab ich keine App im Einsatz.
Re: Probleme mit Octoprint 20. December 2019 07:17 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 616 |
Re: Probleme mit Octoprint 20. December 2019 08:35 |
hafo
Zumindest für deine letzte Frage findest du hier die Lösung [www.gidf.de] für deine anderen Probleme vermutlich auch.
Re: Probleme mit Octoprint 20. December 2019 11:25 |
Re: Probleme mit Octoprint 20. December 2019 14:14 |
Re: Probleme mit Octoprint 20. December 2019 14:17 |
AlterBastler
Warum muß man unter Windows unbedingt Octoprint als Host benutzen?
Ein Raspberry kostet weitaus weniger als die Zeit, die Du bereits investiert hast.
Re: Probleme mit Octoprint 21. December 2019 13:31 |
Re: Probleme mit Octoprint 22. December 2019 09:12 |
Re: Probleme mit Octoprint 25. December 2019 06:14 |
Das ist schon mal super was ich jetzt noch benötigen würde wäre so ein Bat File für den shutdown von Octoprint.
hotprinter
Und noch zu deinem Display:
soweit ich dich verstande habe, möchtest du die Restzeit angezeigt bekommen, die der Drucker noch läuft, oder ? Ist zwar ein wenig verschwommen, deine Aufnahme, aber ich würde mal tippen, es ist das blaue Icon (Sanduhr), das die Restzeit anzeigt ....
Re: Probleme mit Octoprint 28. December 2019 13:32 |
