Endstops und Homing 10. January 2020 01:28 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 12 |
Re: Endstops und Homing 10. January 2020 03:36 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.890 |
Re: Endstops und Homing 10. January 2020 10:21 |
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
Re: Endstops und Homing 10. January 2020 10:48 |
Re: Endstops und Homing 10. January 2020 13:49 |
/** * Thermal Protection provides additional protection to your printer from damage * and fire. Marlin always includes safe min and max temperature ranges which * protect against a broken or disconnected thermistor wire. * * The issue: If a thermistor falls out, it will report the much lower * temperature of the air in the room, and the the firmware will keep * the heater on. * * The solution: Once the temperature reaches the target, start observing. * If the temperature stays too far below the target (hysteresis) for too * long (period), the firmware will halt the machine as a safety precaution. * * If you get false positives for "Thermal Runaway", increase * THERMAL_PROTECTION_HYSTERESIS and/or THERMAL_PROTECTION_PERIOD */ #if ENABLED(THERMAL_PROTECTION_HOTENDS) #define THERMAL_PROTECTION_PERIOD 40 // Seconds #define THERMAL_PROTECTION_HYSTERESIS 4 // Degrees Celsius /** * Whenever an M104, M109, or M303 increases the target temperature, the * firmware will wait for the WATCH_TEMP_PERIOD to expire. If the temperature * hasn't increased by WATCH_TEMP_INCREASE degrees, the machine is halted and * requires a hard reset. This test restarts with any M104/M109/M303, but only * if the current temperature is far enough below the target for a reliable * test. * * If you get false positives for "Heating failed", increase WATCH_TEMP_PERIOD * and/or decrease WATCH_TEMP_INCREASE. WATCH_TEMP_INCREASE should not be set * below 2. */ #define WATCH_TEMP_PERIOD 180 // Seconds (war 20) #define WATCH_TEMP_INCREASE 2 // Degrees Celsius #endif /** * Thermal Protection parameters for the bed are just as above for hotends. */ #if ENABLED(THERMAL_PROTECTION_BED) #define THERMAL_PROTECTION_BED_PERIOD 20 // Seconds #define THERMAL_PROTECTION_BED_HYSTERESIS 2 // Degrees Celsius /** * As described above, except for the bed (M140/M190/M303). */ #define WATCH_BED_TEMP_PERIOD 240 // Seconds (war 60) #define WATCH_BED_TEMP_INCREASE 2 // Degrees Celsius #endif #if ENABLED(PIDTEMP) // this adds an experimental additional term to the heating power, proportional to the extrusion speed. // if Kc is chosen well, the additional required power due to increased melting should be compensated. //#define PID_EXTRUSION_SCALING #if ENABLED(PID_EXTRUSION_SCALING) #define DEFAULT_Kc (100) //heating power=Kc*(e_speed) #define LPQ_MAX_LEN 50 #endif #endif
Re: Endstops und Homing 10. January 2020 13:59 |
Re: Endstops und Homing 10. January 2020 14:34 |
Re: Endstops und Homing 10. January 2020 15:38 |
Re: Endstops und Homing 10. January 2020 17:10 |
Re: Endstops und Homing 10. January 2020 20:14 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 616 |
Re: Endstops und Homing 10. January 2020 20:36 |
Re: Endstops und Homing 11. January 2020 13:32 |
Re: Endstops und Homing 11. January 2020 20:33 |
Re: Endstops und Homing 12. January 2020 10:34 |
Re: Endstops und Homing 12. January 2020 17:42 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 125 |
Re: Endstops und Homing 12. January 2020 17:57 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 199 |
Re: Endstops und Homing 13. January 2020 08:11 |
