Ramps 1.4 Rostock Sainssmart LCD 05. October 2013 14:27 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 6 |
Re: Ramps 1.4 Rostock Sainssmart LCD 05. October 2013 14:38 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.916 |
Marlin V1 (new)
In "Configuration.h”
Change line 46 to “#define MOTHERBOARD 33”
Change line 306 to “#define REPRAP_DISCOUNT_SMART_CONTROLLER” (just remove the // at the beginning)
Change line 326 to “#define NEWPANEL //enable this if you have a click-encoder panel” (just remove the // at the beginning)
Switch over to "Pins.h" and change line 318 to “#define RAMPS_V_1_3” (just remove the // at the beginning)
Re: Ramps 1.4 Rostock Sainssmart LCD 05. October 2013 14:54 |
start echo: External Reset Marlin 1.0.0 echo: Last Updated: Oct 5 2013 20:47:11 | Author: (none, default config) Compiled: Oct 5 2013 echo: Free Memory: 4004 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded echo: Steps per unit: echo: M92 X78.74 Y78.74 Z533.33 E836.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E25.00 echo:Maximum Acceleration (mm/s2): echo: M201 X9000 Y9000 Z100 E10000 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S3000.00 T3000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 echo:Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo: PID settings: echo: M301 P22.20 I1.08 D114.00 Error:0 : Extruder switched off. MAXTEMP triggered ! Error: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) echo: SD init fail
Re: Ramps 1.4 Rostock Sainssmart LCD 11. October 2013 03:51 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 339 |
Re: Ramps 1.4 Rostock Sainssmart LCD 11. October 2013 04:41 |
