GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 14:44 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 16 |
*/ #define NUM_EXTRUDER 1 #define MOTHERBOARD 71 #include "pins.h" // ################## EDIT THESE SETTINGS MANUALLY ################ // ################ END MANUAL SETTINGS ########################## #define FAN_BOARD_PIN -1 #define Y_MIN_PIN 1 #define Z_MIN_PIN 2 #define X_MAX_PIN 0 #define Y_MAX_PIN 1 #define Z_MAX_PIN 2 //#define EXTERNALSERIAL use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer. // Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0 // If it is incompatible you will get compiler errors about write functions not beeing compatible! //#define COMPAT_PRE1 #define DRIVE_SYSTEM 0 #define XAXIS_STEPS_PER_MM 90.901358 //89.265134 //86.76571 //88.153961//78.633333 //47.18 #define YAXIS_STEPS_PER_MM 86.495575 //86.737763 //84.51971 //78.633333 //47.18 #define ZAXIS_STEPS_PER_MM 2499.9469 //2619.9443 //2598.9848 //2560 //1280 #define EXTRUDER_FAN_COOL_TEMP 50 #define EXT0_X_OFFSET 0 #define EXT0_Y_OFFSET 0 #define EXT0_STEPS_PER_MM 370 #define EXT0_TEMPSENSOR_TYPE 8 //1 #define EXT0_TEMPSENSOR_PIN TEMP_0_PIN #define EXT0_HEATER_PIN HEATER_0_PIN #define EXT0_STEP_PIN ORIG_E0_STEP_PIN #define EXT0_DIR_PIN ORIG_E0_DIR_PIN #define EXT0_INVERSE 0 #define EXT0_ENABLE_PIN E0_ENABLE_PIN #define EXT0_ENABLE_ON 0 #define EXT0_MAX_FEEDRATE 50 #define EXT0_MAX_START_FEEDRATE 20 #define EXT0_MAX_ACCELERATION 1000 //5000 #define EXT0_HEAT_MANAGER 3 #define EXT0_WATCHPERIOD 1 #define EXT0_PID_INTEGRAL_DRIVE_MAX 230 #define EXT0_PID_INTEGRAL_DRIVE_MIN 40 #define EXT0_PID_P 7 #define EXT0_PID_I 2 #define EXT0_PID_D 40 #define EXT0_PID_MAX 255 #define EXT0_ADVANCE_K 0 #define EXT0_ADVANCE_L 0 #define EXT0_ADVANCE_BACKLASH_STEPS 0 #define EXT0_WAIT_RETRACT_TEMP 150 #define EXT0_WAIT_RETRACT_UNITS 0 #define EXT0_SELECT_COMMANDS "" #define EXT0_DESELECT_COMMANDS "" #define EXT0_EXTRUDER_COOLER_PIN -1 #define EXT0_EXTRUDER_COOLER_SPEED 255 #define RETRACT_DURING_HEATUP true #define PID_CONTROL_RANGE 20 #define SKIP_M109_IF_WITHIN 2 #define SCALE_PID_TO_MAX 0 #define TEMP_HYSTERESIS 0 #define EXTRUDE_MAXLENGTH 160 #define NUM_TEMPS_USERTHERMISTOR0 0 #define USER_THERMISTORTABLE0 {} #define NUM_TEMPS_USERTHERMISTOR1 0 #define USER_THERMISTORTABLE1 {} #define NUM_TEMPS_USERTHERMISTOR2 0 #define USER_THERMISTORTABLE2 {} #define GENERIC_THERM_VREF 5 #define GENERIC_THERM_NUM_ENTRIES 33 #define HEATER_PWM_SPEED 0 // ############# Heated bed configuration ######################## #define HAVE_HEATED_BED 0 #define HEATED_BED_MAX_TEMP 120 #define SKIP_M190_IF_WITHIN 3 #define HEATED_BED_SENSOR_TYPE 1 #define HEATED_BED_SENSOR_PIN TEMP_1_PIN #define HEATED_BED_HEATER_PIN HEATER_1_PIN #define HEATED_BED_SET_INTERVAL 5000 #define HEATED_BED_HEAT_MANAGER 0 #define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255 #define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80 #define HEATED_BED_PID_PGAIN 196 #define HEATED_BED_PID_IGAIN 33 #define HEATED_BED_PID_DGAIN 290 #define HEATED_BED_PID_MAX 255 #define MIN_EXTRUDER_TEMP 150 #define MAXTEMP 275 #define MIN_DEFECT_TEMPERATURE -10 #define MAX_DEFECT_TEMPERATURE 290 // ################ Endstop configuration ##################### #define ENDSTOP_PULLUP_X_MIN true //false #define ENDSTOP_PULLUP_Y_MIN true #define ENDSTOP_PULLUP_Z_MIN true // --------------------------------------- #define ENDSTOP_PULLUP_X_MAX false//true #define ENDSTOP_PULLUP_Y_MAX false #define ENDSTOP_PULLUP_Z_MAX false #define ENDSTOP_X_MIN_INVERTING false #define ENDSTOP_Y_MIN_INVERTING false #define ENDSTOP_Z_MIN_INVERTING false //--------------------------------------- #define ENDSTOP_X_MAX_INVERTING false #define ENDSTOP_Y_MAX_INVERTING false #define ENDSTOP_Z_MAX_INVERTING false #define MIN_HARDWARE_ENDSTOP_X true //false #define MIN_HARDWARE_ENDSTOP_Y true #define MIN_HARDWARE_ENDSTOP_Z true #define MAX_HARDWARE_ENDSTOP_X false //true #define MAX_HARDWARE_ENDSTOP_Y false #define MAX_HARDWARE_ENDSTOP_Z false #define max_software_endstop_r true #define min_software_endstop_x false #define min_software_endstop_y false #define min_software_endstop_z false #define max_software_endstop_x false #define max_software_endstop_y false #define max_software_endstop_z false #define ENDSTOP_X_BACK_MOVE 3 #define ENDSTOP_Y_BACK_MOVE 3 #define ENDSTOP_Z_BACK_MOVE 3 #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_X_BACK_ON_HOME 0 #define ENDSTOP_Y_BACK_ON_HOME 0 #define ENDSTOP_Z_BACK_ON_HOME 0 #define ALWAYS_CHECK_ENDSTOPS 0 // ################# XYZ movements ################### // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 0 #define DISABLE_E 0 #define INVERT_X_DIR 1 #define INVERT_Y_DIR 0 #define INVERT_Z_DIR 0 // 1 = MAX / -1 = MIN #define X_HOME_DIR -1 //Endschalter bei MAX = rechts MIN?? #define Y_HOME_DIR -1 //Endschlater bei MAX = vorne #define Z_HOME_DIR -1 //Endschalter bei MIN = unten //Nulpunkt also unten vorne links #define X_MAX_LENGTH 100 #define Y_MAX_LENGTH 100 #define Z_MAX_LENGTH 180 #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 //180 // ########################################################################################## // ## Movement settings ## // ########################################################################################## #define FEATURE_BABYSTEPPING 1 #define BABYSTEP_MULTIPLICATOR 1 #define DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for print moves #define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves // Delta settings #define DELTA_HOME_ON_POWER 0 #define MAX_DELTA_SEGMENTS_PER_LINE 24 #define STEPPER_INACTIVE_TIME 360L #define MAX_INACTIVE_TIME 0L #define MAX_FEEDRATE_X 100 /200 #define MAX_FEEDRATE_Y 100 /200 #define MAX_FEEDRATE_Z 50 /200 #define HOMING_FEEDRATE_X 15 #define HOMING_FEEDRATE_Y 15 #define HOMING_FEEDRATE_Z 5 #define HOMING_ORDER HOME_ORDER_ZXY #define ENABLE_BACKLASH_COMPENSATION 0 #define X_BACKLASH 0 #define Y_BACKLASH 0 #define Z_BACKLASH 0 #define RAMP_ACCELERATION 1 #define STEPPER_HIGH_DELAY 1 //0 #define STEP_DOUBLER_FREQUENCY 12000 #define ALLOW_QUADSTEPPING 1 #define DOUBLE_STEP_DELAY 1 // time in microseconds #define MAX_HALFSTEP_INTERVAL 1999 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 800 //1000 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800 //1000 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 800 //1000 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800 //1000 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100 //100 #define MAX_JERK 20 #define MAX_ZJERK 0.3 #define MOVE_CACHE_SIZE 16 #define MOVE_CACHE_LOW 10 #define LOW_TICKS_PER_MOVE 250000 #define FEATURE_TWO_XSTEPPER 0 #define X2_STEP_PIN ORIG_E1_STEP_PIN #define X2_DIR_PIN ORIG_E1_DIR_PIN #define X2_ENABLE_PIN E1_ENABLE_PIN #define FEATURE_TWO_YSTEPPER 0 #define Y2_STEP_PIN ORIG_E1_STEP_PIN #define Y2_DIR_PIN ORIG_E1_DIR_PIN #define Y2_ENABLE_PIN E1_ENABLE_PIN #define FEATURE_TWO_ZSTEPPER 0 #define Z2_STEP_PIN ORIG_E1_STEP_PIN #define Z2_DIR_PIN ORIG_E1_DIR_PIN #define Z2_ENABLE_PIN E1_ENABLE_PIN #define FEATURE_DITTO_PRINTING 0 // ################# Misc. settings ################## #define BAUDRATE 115200 #define ENABLE_POWER_ON_STARTUP #define POWER_INVERTING 0 #define KILL_METHOD 1 #define GCODE_BUFFER_SIZE 2 #define ACK_WITH_LINENUMBER #define WAITING_IDENTIFIER "wait" #define ECHO_ON_EXECUTE #define EEPROM_MODE 0 /* ======== Servos ======= Control the servos with M340 P S / ServoID = 0..3 pulseInUs = 500..2500 Servos are controlled by a pulse width normally between 500 and 2500 with 1500ms in center position. 0 turns servo off. WARNING: Servos can draw a considerable amount of current. Make sure your system can handle this or you may risk your hardware! */ #define FEATURE_SERVO 0 #define SERVO0_PIN 11 #define SERVO1_PIN -1 #define SERVO2_PIN -1 #define SERVO3_PIN -1 #define FEATURE_WATCHDOG 0 // #################### Z-Probing ##################### #define FEATURE_Z_PROBE 0 #define Z_PROBE_BED_DISTANCE 10 #define Z_PROBE_PIN -1 #define Z_PROBE_PULLUP 0 #define Z_PROBE_ON_HIGH 0 #define Z_PROBE_X_OFFSET 0 #define Z_PROBE_Y_OFFSET 0 #define Z_PROBE_WAIT_BEFORE_TEST 0 #define Z_PROBE_SPEED 2 #define Z_PROBE_XY_SPEED 150 #define Z_PROBE_SWITCHING_DISTANCE 1 #define Z_PROBE_REPETITIONS 1 #define Z_PROBE_HEIGHT 40 #define Z_PROBE_START_SCRIPT "" #define Z_PROBE_FINISHED_SCRIPT "" #define FEATURE_AUTOLEVEL 1 #define Z_PROBE_X1 20 #define Z_PROBE_Y1 20 #define Z_PROBE_X2 160 #define Z_PROBE_Y2 20 #define Z_PROBE_X3 100 #define Z_PROBE_Y3 160 #ifndef SDSUPPORT // Some boards have sd support on board. These define the values already in pins.h #define SDSUPPORT 0 #define SDCARDDETECT -1 #define SDCARDDETECTINVERTED 0 #endif #define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */ #define ARC_SUPPORT 1 #define FEATURE_MEMORY_POSITION 1 #define FEATURE_CHECKSUM_FORCED 0 #define FEATURE_FAN_CONTROL 1 #define FEATURE_CONTROLLER 0 #define UI_LANGUAGE 0 #define UI_PRINTER_NAME "RepRap" #define UI_PRINTER_COMPANY "Home made" #define UI_PAGES_DURATION 4000 #define UI_ANIMATION 1 #define UI_SPEEDDEPENDENT_POSITIONING 0 #define UI_DISABLE_AUTO_PAGESWITCH 1 #define UI_AUTORETURN_TO_MENU_AFTER 30000 #define FEATURE_UI_KEYS 0 #define UI_ENCODER_SPEED 1 #define UI_KEY_BOUNCETIME 10 #define UI_KEY_FIRST_REPEAT 500 #define UI_KEY_REDUCE_REPEAT 50 #define UI_KEY_MIN_REPEAT 50 #define FEATURE_BEEPER 0 #define CASE_LIGHTS_PIN -1 #define CASE_LIGHT_DEFAULT_ON 1 #define UI_START_SCREEN_DELAY 1000 /** Beeper sound definitions for short beeps during key actions and longer beeps for important actions. Parameter is delay in microseconds and the secons is the number of repetitions. Values must be in range 1..255 */ #define BEEPER_SHORT_SEQUENCE 2,2 #define BEEPER_LONG_SEQUENCE 8,8 #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60 #define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190 #define UI_SET_PRESET_HEATED_BED_TEMP_ABS 110 #define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240 #define UI_SET_MIN_HEATED_BED_TEMP 30 #define UI_SET_MAX_HEATED_BED_TEMP 120 #define UI_SET_MIN_EXTRUDER_TEMP 170 #define UI_SET_MAX_EXTRUDER_TEMP 260 #define UI_SET_EXTRUDER_FEEDRATE 2 #define UI_SET_EXTRUDER_RETRACT_DISTANCE 3 #endif
/**************************************************************************************************************************************************************************************** * Gen7 1.4.1 pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 71 #define KNOWN_BOARD 1 /* +--------\/--------+ INT8 (D 0) PB0 1|> Xmin Temp_Bed {|40 PA0 (AI 0 / D31) INT1 (D 1) PB1 2|> Ymin Temp_Ext {|39 PA1 (AI 1 / D30) INT2 (D 2) PB2 3|> Zmin Xstep >|38 PA2 (AI 2 / D29) PWM (D 3) PB3 4|< Heat_Bed Xdir >|37 PA3 (AI 3 / D28) PWM (D 4) PB4 5|< Heat_Ext Ystep >|36 PA4 (AI 4 / D27) MOSI (D 5) PB5 6| Ydir >|35 PA5 (AI 5 / D26) MIS0 (D 6) PB6 7| MotEn >|34 PA6 (AI 6 / D25) SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24) RST 9| |32 AREF VCC 10| |31 GND GND 11| |30 AVCC XTAL2 12| Zstep >|29 PC7 (D 23) XTAL1 13| Zdir >|28 PC6 (D 22) RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO RX1 (D 10) PD2 16| Estep >|25 PC3 (D 19) TMS TX1 (D 11) PD3 17| Edir >|24 PC2 (D 18) TCK PWM (D 12) PD4 18| |23 PC1 (D 17) SDA PWM (D 13) PD5 19| |22 PC0 (D 16) SCL PWM (D 14) PD6 20| PwrEn >|21 PD7 (D 15) PWM +------------------+ */ #if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega644__) && !defined(__AVR_ATmega1284P__) #error Oops! Make sure you have 'Gen7' selected from the 'Tools -> Boards' menu. #endif //x axis pins #define ORIG_X_STEP_PIN 29 //D29 #define ORIG_X_DIR_PIN 28 //D28 #define ORIG_X_ENABLE_PIN 25 //D25 #define ORIG_X_MIN_PIN 0 #define ORIG_X_MAX_PIN -1 //y axis pins #define ORIG_Y_STEP_PIN 27 //D27 #define ORIG_Y_DIR_PIN 26 //D26 #define ORIG_Y_ENABLE_PIN 25 //D25 #define ORIG_Y_MIN_PIN 0 //1 //-1 #define ORIG_Y_MAX_PIN 1 //z axis pins #define ORIG_Z_STEP_PIN 23 //D23 #define ORIG_Z_DIR_PIN 22 //D22 #define ORIG_Z_ENABLE_PIN 25 //D25 #define ORIG_Z_MIN_PIN 2 #define ORIG_Z_MAX_PIN -1 //extruder pins #define ORIG_E0_STEP_PIN 19 //D19 #define ORIG_E0_DIR_PIN 18 //D18 #define ORIG_E0_ENABLE_PIN 25 //D25 #define TEMP_0_PIN 1 #define TEMP_1_PIN 0 #define HEATER_0_PIN 4 #define HEATER_1_PIN 3 #define HEATER_2_PIN -1 #define TEMP_2_PIN -1 #define SDPOWER -1 #define SDSS -1 #define LED_PIN -1 #define ORIG_FAN_PIN -1 #define PS_ON_PIN 15 //our pin for debugging. #define DEBUG_PIN 0 //our RS485 pins #define TX_ENABLE_PIN 12 #define RX_ENABLE_PIN 13 #define SDPOWER -1 #define SDSS -1 #define SDSSORIG 4 // Needs to set this to output to enable SPI even if other SS is used! #define SCK_PIN 7 #define MISO_PIN 6 #define MOSI_PIN 5 #define E0_PINS ORIG_E0_STEP_PIN,ORIG_E0_DIR_PIN,ORIG_E0_ENABLE_PIN, #define E1_PINS #endif
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 15:22 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 531 |
//x axis pins #define ORIG_X_STEP_PIN 29 //D29 #define ORIG_X_DIR_PIN 28 //D28 #define ORIG_X_ENABLE_PIN 25 //D25 #define ORIG_X_MIN_PIN 0 #define ORIG_X_MAX_PIN -1 //y axis pins #define ORIG_Y_STEP_PIN 27 //D27 #define ORIG_Y_DIR_PIN 26 //D26 #define ORIG_Y_ENABLE_PIN 25 //D25 #define ORIG_Y_MIN_PIN 1 #define ORIG_Y_MAX_PIN -1 //z axis pins #define ORIG_Z_STEP_PIN 23 //D23 #define ORIG_Z_DIR_PIN 22 //D22 #define ORIG_Z_ENABLE_PIN 25 //D25 #define ORIG_Z_MIN_PIN 2 #define ORIG_Z_MAX_PIN -1
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 15:43 |
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 15:54 |
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 15:57 |
Keine Ahnung und davon jede Menge... habe die erste Version mit dem online ToolQuote
Was sind diese ORIG_ Einträge?
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 16:03 |
#define E0_PINS E0_STEP_PIN,E0_DIR_PIN,E0_ENABLE_PIN,
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 16:07 |
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 16:37 |
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 16:49 |
Re: GEN 7 Reptier -Extruder läuft nicht- 10. September 2014 16:57 |
Re: GEN 7 Reptier -Extruder läuft nicht- 11. September 2014 09:51 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 857 |
3D_DruckNix
...schade...
Beim Linux-CNC ist der Konfigurator wirklich gut ! Man darf ihn allerdings auch nur 1x laufen lassen.
Re: GEN 7 Reptier -Extruder läuft nicht- 11. September 2014 10:13 |
Re: GEN 7 Reptier -Extruder läuft nicht- 11. September 2014 10:42 |
Re: GEN 7 Reptier -Extruder läuft nicht- 11. September 2014 10:50 |
Re: GEN 7 Reptier -Extruder läuft nicht- 11. September 2014 12:10 |
Re: GEN 7 Reptier -Extruder läuft nicht- 11. September 2014 19:22 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 01:48 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 05:29 |
3D_DruckNix
Teilerfolg!
Nachdem ich auf den NEUEN Atmel nicht zugreifen konnte ?
Habe ich mit dem Pollin-Avr Bord & Usb Progger den alten uC die Fusebits nochmal
"gerade gebogen" und das Repetier.hex File drüber gebügelt.
Extruder dreht.... leider nur kurz... beim Kalibrieren ist er anscheinend verstopft.
220º haben nicht geholfen in frei zu bekommen.
Das Freilegen folgt dann morgen. Oder heute
Verstehen tue ich leider nicht was da los war
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 06:16 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 06:25 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 06:45 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 07:40 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 08:17 |
#define UI_SET_MAX_EXTRUDER_TEMPbezieht sich auf die Temperatuer die maximal über ein Display (UI) einstellen kannst.
#define MAXTEMP
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 09:14 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 13:50 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 14:16 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 689 |
Re: GEN 7 Reptier -Extruder läuft nicht- 12. September 2014 16:25 |
Re: GEN 7 Reptier -Extruder läuft nicht--gelöst-- 13. September 2014 06:15 |
