RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 29. November 2015 10:13 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 59 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 29. November 2015 10:27 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 3.969 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 29. November 2015 12:08 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 29. November 2015 13:41 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 29. November 2015 14:38 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 49 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 03:45 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 04:46 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 1.444 |
Repetier-Firmware configuration tool for version 0.92.6
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 05:02 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.807 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 06:10 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 06:22 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 06:27 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 06:29 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 06:34 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
void setup() { Serial.begin(9600); } void loop() { int pin; for (pin = 0, pin<=5, pin++) { Serial.println(analogRead(pin)); Serial.println("\n"); } Serial.println("Warten\n"); delay(100); }
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 07:01 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 07:08 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 17:42 |
23:04:56.750 : Disabling all heaters due to detected sensor defect. 23:04:56.750 : DebugLevel:14 23:08:57.806 : No start signal detected - forcing start
Arduino: 1.6.6 (Windows 7), Board: "Arduino Due (Programming Port)" C:\Users\Felix\Documents\Arduino\sketch_nov30d\sketch_nov30d.ino: In function 'void loop()': sketch_nov30d:11: error: expected ';' before ')' token for (pin = 0, pin<=5, pin++) { ^ sketch_nov30d:16: error: expected ')' before ';' token delay(100); ^ exit status 1 expected ';' before ')' token Dieser Report hätte mehr Informationen mit "Ausführliche Ausgabe während der Kompilierung" aktiviert in Datei > Einstellungen.
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 30. November 2015 18:11 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 00:10 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 03:35 |
void setup() { Serial.begin(9600); } void loop() { int pin; for (pin = 0; pin<=5; pin++) { Serial.println(analogRead(pin)); Serial.println("\n"); } Serial.println("Warten\n"); delay(100); }
Warten 1023 1023 1023 Warten 1023
09:14:28.699 : No start signal detected - forcing start 09:14:28.700 : N1 M110 *2 09:14:28.830 : ]N?g9?|_Z]!]ml6?(Ch{?J]N?'9?|kZ]aC-L6?H(?+ 09:14:29.039 : ]N?g9?|_Z7mhx?}!]ml6?(Ch;?kJ]N?'9?|kZ]aCmL6?Hh?+ 09:14:29.350 : ]N?'9?|_Z7mh8?}a}mv?hH;?+J]?9?\+Za}-L6?h(;?+j]N?g9?\+ZDwmH8?]aC-L6?H(?+ 09:14:29.662 : ]N?g9?|_Z}a}mv?hH;?+j]?9?\+Z7mh8?a}mLv?hH;?+j]N?9?\+ZD]aCmL6?Hh? 09:14:30.182 : ]N?'9?|_Z-Hx?}!]ml6?(Ch;?kJ]N?'9?|kZa}-L6?h(;?+j]N?g9?\+ZD,MHx?}!]m6?(Ch;?kJ]N?'9?|kZa}-L6?h(?+j]N?g9?\+_ZD,7Mx?]aC-L6?Hh?+ 09:14:30.288 : ]N?g9?|_Z]a]ml6?Hh{? 09:14:31.849 : ]N?'9?|?Z7mhx?a}-L6?h(?+j]N?g9?\+_ZD}a]m6?hH;?kJ]?9?|+Z,7mx?}a]m6?hH;?kJ]?9?|+Za}mLv?hH;?+j]N?9?\+ZDwmH8?]a]ml6?Hh{?J]N?'9?|?Za}-L6?h(?+j]N?g9?\+_ZDw-Hx?}a]mv?hH;?kJ]?9?|+ZwmH8?]!]ml6?(Ch{?J]N?'9?|k?Z}!]ml6?(Ch;?kJ]N?'9?|kZw-Hx?a}-L6?h(;?+j]N?g9?\+ZDa}mLv?hH;?+j]?9?\+ZMHx?}a]m6?hH;?kJ]?9?|+Z}!]m6?(Ch;?kJ]N?'9?|kZ,Mx?}a}mv?hH;?+J]?9?\+Z]aCmL6?Hh?+
#define EXT0_TEMPSENSOR_PIN TEMP_2_PIN
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 04:08 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 04:13 |
void setup() { Serial.begin(9600); } void loop() { Serial.println(analogRead(A0)); Serial.println("\n"); Serial.println(analogRead(A1)); Serial.println("\n"); Serial.println(analogRead(A2)); Serial.println("\n"); Serial.println(analogRead(A3)); Serial.println("\n"); Serial.println(analogRead(A4)); Serial.println("\n"); Serial.println("Warten\n"); delay(1000); }
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 04:22 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 04:24 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 04:29 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 08:50 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 09:36 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 09:37 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 09:39 |
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 11:45 |
Traumflug
Bei einem nicht beschalteten Pin (Aufsteckboard abgezogen) kann ein wenig elektromagnetische Einstrahlung genügen, um die Spannung am Pin zu ändern.
Re: RADDS 1.5 + e3d v6 + Repetier FW --> Thermistor Probleme 01. December 2015 17:27 |
