Prusa printing fail December 05, 2011 10:54PM |
Re: Prusa printing fail December 06, 2011 02:03AM |
Re: Prusa printing fail December 06, 2011 02:46AM |
Re: Prusa printing fail December 06, 2011 12:34PM |
Re: Prusa printing fail December 09, 2011 04:58PM |
#ifndef CONFIGURATION_H #define CONFIGURATION_H // BASIC SETTINGS: select your board type, thermistor type, axis scaling, and endstop configuration //// The following define selects which electronics board you have. Please choose the one that matches your setup // MEGA/RAMPS up to 1.2 = 3, // RAMPS 1.3 = 33 // Gen6 = 5, // Sanguinololu up to 1.1 = 6 // Sanguinololu 1.2 and above = 62 // Gen 3 Plus = 21 // gen 3 Monolithic Electronics = 22 #define MOTHERBOARD 33 // Comment out the next line to disable RepRap-style accelerations #define REPRAP_ACC //// Thermistor settings: // 1 is 100k thermistor // 2 is 200k thermistor // 3 is mendel-parts thermistor // 4 is 10k thermistor // 5 is ParCan supplied 104GT-2 100K // 6 is EPCOS 100k // 7 is 100k Honeywell thermistor 135-104LAG-J01 #define THERMISTORHEATER 7 #define THERMISTORBED 7 //// Calibration variables // X, Y, Z, E steps per unit //Metric Prusa Mendel with T2.5 belts, 14-tooth pulleys, and Universal Mini extruder: //float axis_steps_per_unit[] = {91.4286, 91.4286, 2560, 30}; //DEFAULT // Metric Prusa Mendel with Wade extruder float axis_steps_per_unit[] = {80, 80, 3200/1.25,700}; // Metric Prusa Mendel with Makergear geared stepper extruder: //float axis_steps_per_unit[] = {80,80,3200/1.25,1380}; // MakerGear Hybrid Prusa Mendel: // Z axis value is for .9 stepper(if you have 1.8 steppers for Z, you need to use 2272.7272) //float axis_steps_per_unit[] = {104.987, 104.987, 4545.4544, 1487}; //// Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool ENDSTOPS_INVERTING = false; //set to true to invert the logic of the endstops //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here // This determines the communication speed of the printer #define BAUDRATE 57600 // Comment out (using // at the start of the line) to disable SD support: //#define SDSUPPORT //// ADVANCED SETTINGS - to tweak parameters // Uncomment the next line and comment out the following two to get the general purpose thermistor tables #include "thermistortables.h" //#include "extruderThermistorTable_100k_EPCOS_B57540G0104J.h" //#include "bedThermistorTable_10k_EPCOS_B57550G103J.h" // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 #define ENABLE_ON 0 // For early Sanguinololus with a joint enable pin // Disables axis when it's not being used. const bool DISABLE_X = false; const bool DISABLE_Y = false; const bool DISABLE_Z = false; const bool DISABLE_E = false; // Inverting axis direction const bool INVERT_X_DIR = false; const bool INVERT_Y_DIR = false; const bool INVERT_Z_DIR = true; const bool INVERT_E_DIR = false; //// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 const bool min_software_endstops = false; //If true, axis won't move to coordinates less than zero. const bool max_software_endstops = true; //If true, axis won't move to coordinates greater than the defined lengths below. const int X_MAX_LENGTH = 200; const int Y_MAX_LENGTH = 200; const int Z_MAX_LENGTH = 100; // Sensible feedrates #define SLOW_XY 1500.0 // Feedrate from which the motors can do a standing start #define FAST_XY 2500.0 // Fastest feedrate possible #define SLOW_Z 50.0 // Feedrate from which the motors can do a standing start #define FAST_Z 50.0 // Fastest feedrate possible //// MOVEMENT SETTINGS const int NUM_AXIS = 4; // The axis order in all axis related arrays is X, Y, Z, E float max_feedrate[] = {200000, 200000, 240, 500000}; float homing_feedrate[] = {1500,1500,120}; bool axis_relative_modes[] = {false, false, false, false}; // Min step delay in microseconds. If you are experiencing missing steps, try to raise the delay microseconds, but be aware this // If you enable this, make sure STEP_DELAY_RATIO is disabled. //#define STEP_DELAY_MICROS 1 // Step delay over interval ratio. If you are still experiencing missing steps, try to uncomment the following line, but be aware this // If you enable this, make sure STEP_DELAY_MICROS is disabled. (except for Gen6: both need to be enabled.) //#define STEP_DELAY_RATIO 0.25 // Comment this to disable ramp acceleration #define RAMP_ACCELERATION //// Acceleration settings #ifdef RAMP_ACCELERATION // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. float max_start_speed_units_per_second[] = {25.0,25.0,0.2,10.0}; long max_acceleration_units_per_sq_second[] = {1000,1000,50,10000}; // X, Y, Z and E max acceleration in mm/s^2 for printing moves or retracts long max_travel_acceleration_units_per_sq_second[] = {500,500,50,500}; // X, Y, Z max acceleration in mm/s^2 for travel moves #endif // Machine UUID // This may be useful if you have multiple machines and wish to identify them by using the M115 command. // By default we set it to zeros. char uuid[] = "00000000-0000-0000-0000-000000000000"; //// AD595 THERMOCOUPLE SUPPORT UNTESTED... USE WITH CAUTION!!!! //// PID settings: // Uncomment the following line to enable PID support. This is untested and could be disastrous. Be careful. //#define PIDTEMP #ifdef PIDTEMP #define PID_MAX 255 // limits current to nozzle #define PID_INTEGRAL_DRIVE_MAX 220 #define PID_PGAIN 180 //100 is 1.0 #define PID_IGAIN 2 //100 is 1.0 #define PID_DGAIN 100 //100 is 1.0 #endif // How often should the heater check for new temp readings, in milliseconds #define HEATER_CHECK_INTERVAL 500 #define BED_CHECK_INTERVAL 5000 // Comment the following line to enable heat management during acceleration #define DISABLE_CHECK_DURING_ACC #ifndef DISABLE_CHECK_DURING_ACC // Uncomment the following line to disable heat management during moves #define DISABLE_CHECK_DURING_MOVE #endif // Uncomment the following line to disable heat management during travel moves (and extruder-only moves, eg: retracts), strongly recommended if you are missing steps mid print. // Probably this should remain commented if are using PID. // It also defines the max milliseconds interval after which a travel move is not considered so for the sake of this feature. #define DISABLE_CHECK_DURING_TRAVEL 1000 //// Temperature smoothing - only uncomment this if your temp readings are noisy (Gen6 without EvdZ's 5V hack) //#define SMOOTHING //#define SMOOTHFACTOR 16 //best to use a power of two here - determines how many values are averaged together by the smoothing algorithm //// Experimental watchdog and minimal temp // The watchdog waits for the watchperiod in milliseconds whenever an M104 or M109 increases the target temperature // If the temperature has not increased at the end of that period, the target temperature is set to zero. It can be reset with another M104/M109 //#define WATCHPERIOD 5000 //5 seconds //// The minimal temperature defines the temperature below which the heater will not be enabled #define MINTEMP 5 //// Experimental max temp // When temperature exceeds max temp, your heater will be switched off. // This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure! // You should use MINTEMP for thermistor short/failure protection. #define MAXTEMP 275 // Select one of these only to define how the nozzle temp is read. #define HEATER_USES_THERMISTOR //#define HEATER_USES_AD595 //#define HEATER_USES_MAX6675 // Select one of these only to define how the bed temp is read. #define BED_USES_THERMISTOR //#define BED_USES_AD595 // Uncomment the following line to enable debugging. You can better control debugging below the following line //#define DEBUG //#ifdef DEBUG // #define DEBUG_PREPARE_MOVE //Enable this to debug prepare_move() function //#define DEBUG_BRESENHAM //Enable this to debug the Bresenham algorithm //#define DEBUG_RAMP_ACCELERATION //Enable this to debug all constant acceleration info //#define DEBUG_MOVE_TIME //Enable this to time each move and print the result //#define DEBUG_HEAT_MGMT //Enable this to debug heat management. WARNING, this will cause axes to jitter! //#define DEBUG_DISABLE_CHECK_DURING_TRAVEL //Debug the namesake feature, see above in this file //#endif #endif
Re: Prusa printing fail February 05, 2012 04:28AM |
