Polish a printed PLA Part
March 03, 2012 10:08PM
Has anyone got a way to polish a printed PLA part.
I have printed some parts, and want to clean them up, and make them shiny.
SteveMac
Re: Polish a printed PLA Part
March 03, 2012 10:14PM
The very first time you expose 4043D PLA to acetone it melts the surface and you can smooth it out if you're applying it with a paper towel. But after a few seconds it seems to be impervious to the acetone and it stops working. Maybe other mixes of PLA available in Europe and Asia will act differently.
March 07, 2012 08:47AM
How about sanding, then varnish spraying ? Not tried that yet myself.
March 07, 2012 04:01PM
I have tried sanding but i wasn't happy with the result on complex parts.
I will look at some varnishs and clear coats and try some.
Thanks
Steve
March 07, 2012 06:35PM
Acetone is not a chemical you want to mess with on a regular basis. PLA is just plastic. I'd go the route of adding a hard coating to it. Problem is that many hard coatings are also not to be messed with on a regular basis... like epoxy. You can brush or spray on a number of the better synthetic wood glues. I guess it all depends what you are trying to accomplish.
March 08, 2012 11:21PM
Acetone is basically harmless to humans. However, it is very flammable, and should not be used in large quantities and in confined unventilated spaces.
Our body naturally produces small amounts of it, and surprisingly large amounts can be found in cheap liquor.
www.Fablicator.com
December 23, 2012 06:15PM
One thing that works for polishing PLA is the extremely careful application of heat, so the surface just begins to melt. I have successfully polished rough edges by holding them over a clean flame (like natural gas on a stove) for a very short amount of time (a second or so at the most). But of course, the biggest drawback here is that the heat must be applied very carefully and very quickly so as not to distort the part. Using this flame method is very touchy -- it is hard to control and you may end up over-melting. An idea I have considered, but not tried yet, is using a hot air gun (or air "pencil" like they use for surface mount soldering touch-up), with a very small aperature or nozzle. I imagine using it in very small areas at a time. The temperature and spread of the air from the nozzle, and distance from the nozzle would be somewhat critical. It would be much like using an airbrush, I think. I will probably give it a try one of these days.
January 01, 2013 06:41PM
i use a lighter to heat it up and press it to a flat surface. Doesnt work good in every case tho.
