PrintBed leveling - prusa June 29, 2012 05:40PM |
Re: PrintBed leveling - prusa June 29, 2012 07:56PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: PrintBed leveling - prusa June 29, 2012 09:21PM |
Re: PrintBed leveling - prusa June 30, 2012 07:35PM |
Re: PrintBed leveling - prusa July 01, 2012 10:58AM |
Re: PrintBed leveling - prusa July 01, 2012 01:12PM |
nophead - thanks, I might try that once all else fails, trying not to spend more money.
Re: PrintBed leveling - prusa July 02, 2012 12:07PM |
Re: PrintBed leveling - prusa July 02, 2012 12:44PM |
Re: PrintBed leveling - prusa July 02, 2012 02:30PM |
nophead
If the Y bars are not parallel you wont be able to
level it, so that is probably your problem. This
is one of the many issues I addressed with
Mendel90.
Re: PrintBed leveling - prusa July 02, 2012 05:20PM |
Re: PrintBed leveling - prusa July 03, 2012 07:29AM |
Re: PrintBed leveling - prusa July 03, 2012 10:53AM |
Re: PrintBed leveling - prusa July 04, 2012 11:33AM |
Re: PrintBed leveling - prusa July 04, 2012 12:49PM |
Re: PrintBed leveling - prusa July 04, 2012 03:37PM |
Re: PrintBed leveling - prusa July 05, 2012 07:48AM |
Re: PrintBed leveling - prusa July 05, 2012 09:38PM |
Re: PrintBed leveling - prusa July 06, 2012 06:47AM |
Even if the bars are not perfectly level it's fine since you can compensate for that error by lifting and leveling your actual print surface independent from what your actual bearings are attached to.
Re: PrintBed leveling - prusa July 09, 2012 09:48AM |
nophead
Also the sag in the bars due to the weight of the bed and the extruder make the bed appear to have a saddle shape.
Re: PrintBed leveling - prusa July 09, 2012 11:01AM |
Re: PrintBed leveling - prusa July 09, 2012 11:10AM |
Re: PrintBed leveling - prusa July 11, 2012 09:31PM |
dustynus
If the whole bed is able to move smoothly back and forth then the bars must be parallel.
Re: PrintBed leveling - prusa July 12, 2012 04:37AM |
Re: PrintBed leveling - prusa July 12, 2012 07:25AM |
nophead
I would measure the height to the base with digital callipers by standing one jaw on the ground and using the other jaw for measuring inside to measure the height under the bar.
nophead
Is the surface you stand it on definitely flat?
Re: PrintBed leveling - prusa July 12, 2012 09:13AM |
Re: PrintBed leveling - prusa July 12, 2012 10:00AM |
