Pockmarks on surface November 08, 2016 02:37PM |
Re: Switching from PETG to PLA November 08, 2016 04:19PM |
Re: Switching from PETG to PLA November 08, 2016 04:23PM |
Re: Switching from PETG to PLA November 08, 2016 04:49PM |
PDBeal
Cheap filament is exactly that, cheap and inconsistent...
If you use some other filament, does it still go inconsistent or is it any better? From what I've seen the eSun filament is about the same $20-$24 per spool for 1kg with their PLA Pro being $25-$35 per 1kg, so you might not have true eSun filament at $14.
Re: Switching from PETG to PLA November 09, 2016 10:18AM |
Re: Switching from PETG to PLA November 09, 2016 12:28PM |
Re: Pockmarks on surface November 10, 2016 11:47AM |
Re: Pockmarks on surface November 10, 2016 12:03PM |
Re: Pockmarks on surface November 10, 2016 01:07PM |
Re: Pockmarks on surface November 10, 2016 01:11PM |
Re: Pockmarks on surface November 10, 2016 01:28PM |
Re: Pockmarks on surface November 10, 2016 01:47PM |
Re: Pockmarks on surface November 13, 2016 01:26PM |
Re: Pockmarks on surface November 14, 2016 10:45AM |
T0 ; Select Tool 0 M82 ; Set extruder to absolute mode G28 ; Home X, Y, and Z G32 ; Probe Z and calculate Z plane G1 Z15.0 F6000 ;Move the platform down 15mm G92 E0 G1 F200 E10 G92 E0
;FLAVOR:RepRap ;TIME:3185 ;Generated with Cura_SteamEngine 2.3.0 M190 S65 M104 S200 M109 S200 T0 ; Select Tool 0 M82 ; Set extruder to absolute mode G28 ; Home X, Y, and Z G32 ; Probe Z and calculate Z plane G1 Z15.0 F6000 ;Move the platform down 15mm G92 E0 G1 F200 E5 G92 E0 ;LAYER_COUNT:240 ;LAYER:0 M107 G1 F1800 E-3.5 G1 Z22 G0 F4500 X120.424 Y91.505 Z2.2 ;TYPEKIRT G1 Z.2 G1 F1800 E0 G1 X120.971 Y90.805 E0.03546 G1 X121.379 Y90.349 E0.05988 etc...
Re: Pockmarks on surface November 14, 2016 11:24AM |
Re: Pockmarks on surface November 15, 2016 08:00PM |
G1 X72.300 Y97.300 E132.75066 F736.948
G1 X71.807 Y73.193 E135.78426 F1052.783
; external_perimeter_extrusion_width = 0 (this is auto) ; external_perimeter_speed = 70% ; external_perimeters_first = 1 ; perimeter_extrusion_width = 0 ; perimeter_speed = 30 ; perimeters = 2 ; small_perimeter_speed = 10
G1 X47.700 Y72.700 E55.24330 F1260.000
Re: Pockmarks on surface November 16, 2016 12:24PM |
Re: Pockmarks on surface November 17, 2016 01:05PM |
FA-MAS
Edit: Now begs the question
They say outer perimeters should be printed thinner and slower to allow for higher details.
But when you do the math, the flow rate differs greatly between it and the inner perimeter.
To get them even close, the outer perimeter would actually have to be printed wider right?
Seems counter intuitive.
Would it be best to just print everything at the same width and speed? Internal & External perimeters. Say find an average thickness you'd like to use between perimeters and infill, and print them all at an average speed?
Re: Pockmarks on surface November 19, 2016 02:41PM |
;LAYER:1 M106 S255 G0 F1350 X85.753 Y63.7 Z.4 G0 X63.29 Y63.29 G0 X62.74 Y62.74 ;TYPE:WALL-OUTER G1 X87.26 Y62.74 E70.14428 G1 X87.26 Y87.26 E71.12293 G1 X62.74 Y87.26 E72.10158 G1 X62.74 Y62.74 E73.08022 G0 X63.22 Y63.22
Re: Pockmarks on surface November 19, 2016 04:39PM |
Re: Pockmarks on surface November 19, 2016 05:41PM |
Re: Pockmarks on surface November 19, 2016 10:33PM |
Re: Pockmarks on surface November 21, 2016 12:39PM |
Re: Pockmarks on surface November 21, 2016 03:53PM |
Re: Pockmarks on surface November 21, 2016 04:18PM |
Re: Pockmarks on surface November 22, 2016 02:19AM |
Re: Pockmarks on surface November 22, 2016 04:59AM |
FA-MAS
Closer inspection, it looks like it is at the start of each layer. It does the outer perimeter first and it does looks like there's no filament for that first section. I know it's not retract distance because it's not retracting on layer change. But I do notice sometimes as it positions to do the next layer, that there's a little bit of ooze that dribbles across the infill. Maybe add a little length on restart?
Re: Pockmarks on surface November 22, 2016 08:44AM |
Re: Pockmarks on surface November 22, 2016 01:05PM |
Re: Pockmarks on surface November 28, 2016 02:07PM |
