Which support material to use? May 20, 2017 02:48PM |
Re: Which support material to use? May 20, 2017 05:11PM |
Re: Which support material to use? May 31, 2017 01:46PM |
RudydG
There are 3 options (beside using 1 head, and the same material as support)
-Hips, but there you need chemicals to remove it.
-Pva, only tapwater to remove this material.
-Polymaker's Polysupport. Easy to remove, but functionaly the same as using the same material, but with almost no traces.
Ps, dual extrusion (what you need for there support options) is not easy, and requires quite a lot of practice.
Re: Which support material to use? June 01, 2017 07:19AM |
