Issues printing at 0.2mm April 19, 2018 02:29PM |
Re: Issues printing at 0.2mm April 19, 2018 02:59PM |
Re: Issues printing at 0.2mm April 19, 2018 03:11PM |
jaded
Make sure your nozzle gap is correct (bed leveling).
Try first layer height at 0.3mm.
If you are using slic3r set the first layer extrusion width to 200%.
Set infill before perimeters.
Perimeters to 3.
Try slowing down your first layer speeds.
Check your temperatures (bed and hotend).
Make sure your extrusion rate multiplier in your slicer (I use slic3r) is correct to your hardware feedrate.
Re: Issues printing at 0.2mm April 19, 2018 04:26PM |
Re: Issues printing at 0.2mm April 19, 2018 04:48PM |
Rossos
My printer can't make 0.3mm, it's either 0.28mm or 0.32mm.
Maybe your issue lies within the lead screws. Make sure they can accommodate your desires.
Prusa Calculator:
Lead Screws: [www.prusaprinters.org]
Optimal Layer Height: [www.prusaprinters.org]
Re: Issues printing at 0.2mm April 19, 2018 10:05PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Issues printing at 0.2mm April 20, 2018 02:04AM |
Dust
m8 is 1.25mm per rotation presuming that you have 1/16th microstepping and a 200 step stepper.
then you have 2560 steps/mm
so 0.2mm is 32 steps and is accurate.
So the mechanics are fine.
Re: Issues printing at 0.2mm April 20, 2018 02:30AM |
Re: Issues printing at 0.2mm April 20, 2018 02:54PM |
Re: Issues printing at 0.2mm April 20, 2018 07:47PM |
Re: Issues printing at 0.2mm April 21, 2018 01:10AM |
orbitalair
Your nozzle is too high.
Recalibrate the nozzle Z=0 to be 1 sheet of paper thickness with some drag off the plate.
I seriously doubt you get good objects with a 0.4mm nozzle at 0.4mm layer height, the layers are barely sticking to each other.
