Autolevel doesn´t compensate enough May 13, 2018 08:38AM |
Re: Autolevel doesn´t compensate enough May 13, 2018 10:17AM |
Suggestion to help with bed leveling.Quote
Kutulu
1st problem: Although my Z offset is correct, the printer is too close to the printbed but only on the back of the printbed, prints fine on the front of the printbed. The Z motor moves while printing but seems like its not enough to compensate for the bed tilt.
2nd problem: The distance between each layer is too big and therefore the next layer is always a little bit too thin and doesnt adhere to the previous layer enough. My Steps per mm have been calibrated properly so it cant be that.
Re: Autolevel doesn´t compensate enough May 13, 2018 11:44AM |
Re: Autolevel doesn´t compensate enough May 13, 2018 12:26PM |
Re: Autolevel doesn´t compensate enough May 14, 2018 03:05AM |
Re: Autolevel doesn´t compensate enough May 14, 2018 08:57AM |
Re: Autolevel doesn´t compensate enough May 14, 2018 03:12PM |
Re: Autolevel doesn´t compensate enough May 14, 2018 04:33PM |
Re: Autolevel doesn´t compensate enough May 14, 2018 04:58PM |
Re: Autolevel doesn´t compensate enough May 15, 2018 12:55AM |
Re: Autolevel doesn´t compensate enough May 15, 2018 07:59AM |
Kutulu
Start G-Code:
G28 ;Home
G29 ;autolevel
G1 Z15.0 F6000 ;Move the platform down 15mm
;Prime the extruder
G92 E0
G1 F200 E3
G92 E0
Re: Autolevel doesn´t compensate enough May 15, 2018 09:43AM |
Re: Autolevel doesn´t compensate enough May 26, 2018 01:38AM |
Re: Autolevel doesn´t compensate enough May 26, 2018 02:49AM |
