curling mid print and overhangs March 13, 2013 06:06AM |
Re: curling mid print and overhangs March 13, 2013 08:06AM |
Re: curling mid print and overhangs March 13, 2013 08:47AM |
Re: curling mid print and overhangs March 13, 2013 09:58AM |
However you seem to have other quality issues to sort out first before tackling the curling. Slow your printer right down to say 30mm/s for now and lower your acceleration/jerk loads. Make sure your belts are tight and ensure your hotend has zero wobble when hot. Make sure there are no loose fixings on your printer allowing excessive vibration. Confirm your e-calibration is bang on.
You really need a fan to improve the PLA prints. Not sure which slicer you are using but make sure cooling is turned on. Also may want to reduce the temp slightly. You did not give the specs on the heatbed, but 60 degrees and PVA works well.
Re: curling mid print and overhangs March 13, 2013 11:52AM |
Re: curling mid print and overhangs March 15, 2013 01:41PM |
Re: curling mid print and overhangs March 19, 2013 11:26AM |
