Small gaps in outer layers
April 20, 2013 01:23PM
Hi Everyone,
First off the site has been more than valuable at getting me up and running with my prusa. Thanks for all your knowledge smiling smiley
I spent alot of time calibrating my printer before doing any prints and that has paid off a ton. I am having an issue that I cant seem to find a post so here it goes...
I am having very smal gaps in my outer print layers. Not seperating but almost like the print head is going too fast and the plastic is getting stretched. Here is my config and printer setup:
Prusa i2
J-head MKIV-B hot end .5mm
Wades
Heated bed
40mm fan on hot end
Ramps 1.4
Sprinter firmware
Slic3r 0.9.9
Slic3r Config:
# generated by Slic3r 0.9.9 on Sat Apr 20 13:04:12 2013
avoid_crossing_perimeters =
bed_size = 200,200
bed_temperature = 60
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 50
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors\nM107 ; turn off fan\nM140 S0 ; tuen off bed\nM104 S0 ; make sure extruder is off
external_perimeter_speed = 60
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = .85
extrusion_width = 0
fan_always_on =
fan_below_layer_time = 300
filament_diameter = 2.93
fill_angle = 45
fill_density = 0.3
fill_pattern = honeycomb
first_layer_bed_temperature = 60
first_layer_extrusion_width = 200%
first_layer_height = 0.30
first_layer_speed = 30%
first_layer_temperature = 200
g0 = 0
gap_fill_speed = 15
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 50
layer_gcode =
layer_height = 0.35
max_fan_speed = 100
min_fan_speed = 50
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 1
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 20
perimeters = 3
post_process =
print_center = 111,100
raft_layers = 0
randomize_start = 1
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 1
retract_length_toolchange = 10
retract_lift = .5
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 6
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 20
small_perimeter_speed = 20
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 45
start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle
support_material = 0
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 50
support_material_threshold = 0
temperature = 185
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 40
top_solid_layers = 3
travel_speed = 120
use_relative_e_distances = 0
vibration_limit = 0
z_offset = 0
Attached are pictures of the spaces. There is also a picture of the thin wall calibration test. I dont see the issue with it and I have no idea why. Any help would be appreciated.
Thanks,
-Jimmy
open | download - spaces.JPG (461.9 KB)
open | download - thin_wall_test.JPG (231.8 KB)
Re: Small gaps in outer layers
April 21, 2013 11:13PM
You say your Nozzle is .5mm but your Slic3r settings is set to:
Komb'
Glankonian Protoforms
