Hi All
I dont understand this one. My printer seems to slip in Y while printing long lengths however when I tested it with the .4 thin wall stretched by 2 in the Y it was fine. see attached
I have calibrated the XYZ axis to 0.02 in movement and as you see long thin wall worked fine
is a closer shot of what it did trying to print a spring from thingieverse
then
is a calibration test, now i was expecting the Z axis to fall over at 45deg ish but NO its printed straight. I need a fan fitting to stop the twist n sagging but thats later. The calibration test is also 60mm long on each axis and thats what its printed when measured its just moved every couple of layers in the Y every now and then.
Oh and it isnt regular shift either, some layers have printed 3 layers before shift then its done up to 10 more layers before shifting again!!!!
Any ideas as its doing my head in
Mike
