I have been using Cura for some time.. and had a minor issue of blobs on corners.... would love to get this fixed - went back to slic3r.
I have just upgrade to slic3r 1.001 Rc and getting terrible results on corners, there appears to be a vertical groove on every corner, also random dots.
I have duplicated as many settings from cura as I can..
Printing PLA with a direct drive extruder.Mk8 drive gear, on a Prusa i3 - at 70mm/s
Layer height 0.2 mm
Temp 200
I have pulled the acceleration,speed & temp up and down - no difference, at all.
I have tried temp from 185 - 205 .
and speed to 40mm/s
also extrusion width and amount checked many times, and pulled up and down.. not much change , just too much or to little plastic
I have made all adjustments in firmware.
I would really welcome your help. as this is driving me mad.
Would be good to get slic3r and cura working properly,
Slic3r Box
pic1
Slic3r & Cura Box
Pic2
Cura Frog
Pic3
My latest firmware settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {81.65115018964583,80.31,4028,155} // default steps per unit for Prusa was set to 700
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 45} // (mm/sec) DERATED FOR PRUSA FROM 500, 500, 5, 45 DM DEFAULT{300, 300, 5, 45}
#define DEFAULT_MAX_ACCELERATION {9000,9000,45,9000} // 2000X, Y, Z, E maximum start speed for accelerated moves. // DERATED FOR PRUSA FROM DEFAULTS 9000,9000,100,10000. DM DEFAULT{1000,1000,50,500} fault values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // 1200 X, Y, Z and E max acceleration in mm/s^2 for printing moves DERATED FOR PRUSA FROM 3000
#define DEFAULT_RETRACT_ACCELERATION 3000 //1200 X, Y, Z and E max acceleration in mm/s^2 for r retracts DERATED FOR PRUSA FROM 3000
#define DEFAULT_XYJERK 30.0 // (mm/sec)** 30
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)** 5
My original firmware settings
#define DEFAULT_MAX_ACCELERATION {1500,1000,45,9000} // 2000X, Y, Z, E maximum start speed for accelerated moves. // DERATED FOR PRUSA FROM DEFAULTS 9000,9000,100,10000. DM DEFAULT{1000,1000,50,500} fault values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1500 // 1200 X, Y, Z and E max acceleration in mm/s^2 for printing moves DERATED FOR PRUSA FROM 3000
#define DEFAULT_RETRACT_ACCELERATION 1200 //1200 X, Y, Z and E max acceleration in mm/s^2 for r retracts DERATED FOR PRUSA FROM 3000
#define DEFAULT_XYJERK 10.0 // (mm/sec)** 30
#define DEFAULT_EJERK 1.0 // (mm/sec)** 5
not sure where to go from here?
may be look at old slic3r 0.9.8?which in your opinion has been the best version?
The blobs in cura wont go either!
so with everything I have tried I still get blobs with Cura, and funny corners with Slic3r, what am I missing?
Edited 2 time(s). Last edit at 12/23/2013 06:55AM by mrfunk.
