Stringy prints on new eMaker Huxley December 31, 2013 05:57PM |
Re: Stringy prints on new eMaker Huxley December 31, 2013 06:12PM |
Re: Stringy prints on new eMaker Huxley December 31, 2013 06:13PM |
Dirty Steve
Reduce your extruder flow rate, you are over extruding a bit. top surfaces should be smoother and not bulge up like in your prints.
If you are using a Wades type geared extruder, generally you should be around 1mm of retraction. Lower your Z lift to double your layer height. With 2.5mm of retraction the hot-end sets in one spot on the print much longer than it does for 1mm retraction, this will cause little blobs on the exterior of the print.
I think your stringing is coming from a combination of your extruder flow rate, retraction distance, and Z lift.
Re: Stringy prints on new eMaker Huxley December 31, 2013 06:16PM |
Re: Stringy prints on new eMaker Huxley December 31, 2013 07:40PM |
Re: Stringy prints on new eMaker Huxley December 31, 2013 08:14PM |
Re: Stringy prints on new eMaker Huxley December 31, 2013 08:27PM |
Re: Stringy prints on new eMaker Huxley January 01, 2014 02:28AM |
