Problem printing thin wall objects. January 25, 2014 09:53AM |
Re: Problem printing thin wall objects. January 25, 2014 11:51AM |
Re: Problem printing thin wall objects. January 25, 2014 01:57PM |
Re: Problem printing thin wall objects. January 26, 2014 09:08AM |
Re: Problem printing thin wall objects. January 31, 2014 01:06PM |
whitemousegary
Your problem is not about the gcode or the calibration, instead the hardware of your extruder. Be precise, your extruder is not quite extruding. The reason could be too much friction along the tubing, nozzle blockage, or having a poorly designed extruder.
In case of too much friction along the tubing, it can be improved by using PTFE tube all the way to the tip of the nozzle or adding an extruder fan to cool the tube right before the hot end. More than likely, you need both.
In case of nozzle blockage, there is nothing you can do besides finding a more relibable filament vendor. By the way, there is a very popular rumor saying that the filament is being degraded by moisture and therefore the blockage. Some even said that baking the filament in oven can help. NO NO NO, it's just not the case. Nozzle blockage is another way of saying your filament had been contaminated during its production.
In case of poorly designed extruders... A typical faulty extruder design would be http://www.thingiverse.com/thing:87236, which unrealistically assuming printed parts has steel strength. A better design with printed parts would be http://www.thingiverse.com/thing:127873. Take a while to compare, it's obvious.
Playing with "Extra Length on Restart" would help a tiny bit. Unfortunately, it doesn't work in general, i.e. you will still have a lot of random "weird none filling" when you print something with more complicated geometry.
Re: Problem printing thin wall objects. February 02, 2014 01:17AM |
gmh39
... Im using a Printrbot Jr. It's got a fan that blows on the hotend and print, ...
gmh39
I was able to get it working without the "Extra Length on Restart" but I cant remember what I did.
Now I just gotta get this conductive filament to extrude consistently...
Re: Problem printing thin wall objects. February 02, 2014 04:48AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Problem printing thin wall objects. February 02, 2014 01:18PM |
whitemousegary
gmh39
A fan for printing is different from a fan to cool the tube. If the picture above is what you have, you don't have a fan to cool the tube.
gmh39
"conductive filament"... is that the one black in color? If it is so, give it up. I have tried it numerious times, and it just doesn't work.
By the way, transparent filaments are better in quality in general. If transparent, quite a lot kinds of contamination would become visable to naked eyes, which deters the filament vendors from being stupid or cheating. Start with transparent filaments first. It helps a lot for identifing problems.
Re: Problem printing thin wall objects. February 02, 2014 04:40PM |
Re: Problem printing thin wall objects. February 02, 2014 05:17PM |
Re: Problem printing thin wall objects. February 02, 2014 07:43PM |
Re: Problem printing thin wall objects. February 05, 2014 09:27AM |
