Stepper Going Bad? February 10, 2014 08:59PM |
Re: Stepper Going Bad? February 10, 2014 09:56PM |
Re: Stepper Going Bad? February 10, 2014 11:11PM |
Re: Stepper Going Bad? February 11, 2014 12:38AM |
Re: Stepper Going Bad? February 12, 2014 03:48PM |
Re: Stepper Going Bad? February 20, 2014 08:44AM |
Re: Stepper Going Bad? February 20, 2014 12:13PM |
Re: Stepper Going Bad? March 01, 2014 09:39PM |
Re: Stepper Going Bad? March 01, 2014 09:40PM |
gmh39
If you are getting the offset along the same axis after rotating, your belt tension probably needs to be adjusted so they dont slip.
It could also be a current problem, which is easy enough to check so you might as well.
