It looks like inconsistent extrusion, check if filament is slipping on the hobbed bolt, or if extruder is missing steps, or stepper driver is overheating due to wrong current setting.
It could also be bad filament, it looks like it contains quite a bit of moisture.
As for temperature. When printing ABS, hotter is usually better, I print at 245 degrees, and ideally no cooling.
