A bend in the z-axis rod should not cause your hot end to drag through the print and knock it off. It sounds more like an adhesion issue. If you have some masking tape / blue painter's tape lying about, try printing on a layer of that on top of the glass. If you've got some PVA glue, dilute it about 1:1 with water and paint it on the glass (my preferred solution).
Movement in the z-axis is more likely to cause banding in your prints than cause them to be knocked off the glass. Have you noticed any banding in what you've completed so far?
3DKarma.com] - suppliers of quality, affordable 3D printer kits and filament for the UK market.
