layer shift in y axis April 18, 2014 02:35PM |
Re: layer shift in y axis April 19, 2014 12:51AM |
Re: layer shift in y axis April 19, 2014 10:44PM |
Re: layer shift in y axis April 20, 2014 05:06AM |
Re: layer shift in y axis April 21, 2014 04:23AM |
logiwan992
I am having a similar issue. Mine is more consistent, but it is the y direction. The print just starts to slant along the y-axis. Not sure if there is a similar fix but I will watch this thread to see.
Here is a picture where you can somewhat see what I'm talking about. This is just a slight sway, but sometimes its more pronounced.
Re: layer shift in y axis April 23, 2014 06:23PM |
zahmed
logiwan992
for your problem, you need to vary temperature, assumed this is ABS if first layer is with 240C the remaining layers should be extruded with a temperature of 220 - 225 ! this should fix your problems, if this doesnt help then check the level of your bed
