Very bad layer bonding - Problem April 25, 2014 01:09PM |
Re: Very bad layer bonding - Problem April 25, 2014 02:14PM |
Re: Very bad layer bonding - Problem April 25, 2014 02:32PM |
jbernardis
What is your extrusion width? Your extrusion width should be about twice the size of your layer height, if not a little more. I used to specify 220% as the ratio in Slic3r, but I've since moved back to using slic3r defaults, it is giving me a ratio of 280% - my layer height is 0.2, and my resulting extrusion width is 0.56. Having a wider bead increases the top and bottom surface area making for a stronger inter-layer bond.
Re: Very bad layer bonding - Problem April 25, 2014 03:00PM |
Re: Very bad layer bonding - Problem April 25, 2014 03:30PM |
Re: Very bad layer bonding - Problem April 25, 2014 09:32PM |
Re: Very bad layer bonding - Problem April 26, 2014 02:41AM |
Re: Very bad layer bonding - Problem April 28, 2014 07:05AM |
