Do you have a fan blowing on the print also? On the other pictures I can only see a fan pointed towards the hotend, that might not be enough.
Slowing down a bit might also help.
Also have you tried to raise the temperature? if you go too low the plastic might not be fluid enough, when it is extruted, this can be a problem on pointy overhangs.
