Heated bed stop heating!
May 18, 2014 06:23AM
Hello, I have a Prusa i3 Mendel and during a printing my heated bed stoped working. Anyone could tell me what happened?
Thanks!
Re: Heated bed stop heating!
May 18, 2014 11:45PM
Power stopped flowing through your heated bed. Either the + side isn't getting enough power or the - side isn't being shunted to ground when desired.
May 19, 2014 01:47AM
Have you got a fan blowing over your Ramps board (that's if you have Ramps). The yellow fuse has an issue where it can shutdown prematurely due to overheating.
_______________________________________
Waitaki 3D Printer
June 04, 2014 02:24AM
Replace the standard ramps MOSFET for the bed to IRLB8743PBF MOSFET, N CH, 30V, 78A, TO220 or similar, the standard one isn't good enough and will get too hot and eventually fail. The replacement won't even get warm.
June 19, 2014 05:30PM
waitaki how do you fix that problem ? i think that could be my problem as my heatbed fails to reach the correct temp although the hotend reaches it fine having said that, when i turn both on the temps drop. the yellow fuse' do reach a significant temp i have noticed
June 20, 2014 03:35AM
Just install a fan, permanently connected to 12v power.
Waitaki 3D Printer
