I need help identifying the problems of my printer May 20, 2014 06:21AM |
Re: I need help identifying the problems of my printer May 20, 2014 09:47AM |
Re: I need help identifying the problems of my printer May 20, 2014 10:07AM |
cat.farmer
This issue has ben covered many times in the forum, it would be easiest to do a little looking around here.
There are many causes of not sticking - I think the list is almost endless..
the 2 I would look at is bed temp and layer height. make sure your first later is "pressed" down on to the platform.
I too had this issue when I started, now I rarely have problems, seems like once you get it, you got it.
Re: I need help identifying the problems of my printer May 20, 2014 02:15PM |
Re: I need help identifying the problems of my printer May 20, 2014 03:18PM |
Re: I need help identifying the problems of my printer May 20, 2014 03:25PM |
Re: I need help identifying the problems of my printer May 20, 2014 07:43PM |
Re: I need help identifying the problems of my printer May 21, 2014 05:23AM |
Re: I need help identifying the problems of my printer May 21, 2014 08:09AM |
Re: I need help identifying the problems of my printer May 21, 2014 09:46AM |
MrDoctorDIV
I've printed .4mm layer height a lot easier than .1mm [my bed isn't perfectly flat, thanks Obama]. That shouldn't affect squishing. In my firmware I have it set to move away from the endstop 1mm, so when I put my bed at the right z-height I'm not moving it until it's at the nozzle, I'm adjusting my z-height screw and hoping it's right. Maybe your firmware has that same feature turned on and it's moving away. Home your z-axis and see if it's where you set it [unless that's what you've already been doing].
Re: I need help identifying the problems of my printer May 21, 2014 10:05AM |
Re: I need help identifying the problems of my printer June 03, 2014 05:26PM |
Re: I need help identifying the problems of my printer June 06, 2014 11:59PM |
Re: I need help identifying the problems of my printer June 07, 2014 04:11AM |
