Kossel Mini circular objects/ corners small bumps... June 02, 2014 12:43AM |
Re: Kossel Mini circular objects/ corners small bumps... June 02, 2014 01:10AM |
Re: Kossel Mini circular objects/ corners small bumps... June 02, 2014 05:54AM |
Re: Kossel Mini circular objects/ corners small bumps... June 03, 2014 01:30AM |
Re: Kossel Mini circular objects/ corners small bumps... June 03, 2014 05:56AM |
Re: Kossel Mini circular objects/ corners small bumps... June 03, 2014 07:08AM |
Re: Kossel Mini circular objects/ corners small bumps... June 03, 2014 08:14PM |
Re: Kossel Mini circular objects/ corners small bumps... June 03, 2014 11:51PM |
Re: Kossel Mini circular objects/ corners small bumps... June 05, 2014 10:58AM |
Re: Kossel Mini circular objects/ corners small bumps... June 05, 2014 04:32PM |
Re: Kossel Mini circular objects/ corners small bumps... June 05, 2014 09:43PM |
Re: Kossel Mini circular objects/ corners small bumps... June 06, 2014 07:36PM |
Re: Kossel Mini circular objects/ corners small bumps... June 08, 2014 04:08PM |
vreihen
https://groups.google.com/forum/#!msg/deltabot/jwwNE356D04/NSypwPQ-i0MJ
Per Jeff Short's post in the Google Deltabot group, lowering the Delta_segment setting in his firmware down to 50 helped his printer to fix little bumps on the walls of his prints. Giving up accuracy to keep the CPU/memory load down?????
Re: Kossel Mini circular objects/ corners small bumps... February 25, 2015 03:37PM |
Re: Kossel Mini circular objects/ corners small bumps... June 10, 2015 10:58AM |
