Hi, I posted already some items on the forum and always got replied, but one problem doesn't seem to go away. When I print something, larger surfaces and their perimeters look ok. Smaller things are completely smudged after a few layers
As you can see, the bottom printed plate is perfect, in filling as well as perimeters. The smaller parts going up are completely smudged, not even square and the two millimeters in between is even sometimes gone. I have the impression that for these smaller upgoing areas, it does a "complete" fill of the structure... could this be the problem?
How to fix this? I already changed extruder multiplicator in slicer to 0.95, but that doesn't really make a difference. Also, if I put this even lower, I'm afraid the larger areas and perimeters will no longer print correct.
any advice welcome.
Kind regards
Wim
