x axis jumps
Posted by soaring eagle
x axis jumps
June 24, 2014 04:27PM
I am biulding a reprap i2 i got it or so i thought but it turned out i can only print smaller than 40mm and they also turn out wavy on both the x and y axis any suggestions
Edited 1 time(s). Last edit at 06/25/2014 04:12PM by soaring eagle.
Re: prints wavy
June 24, 2014 04:47PM
Make sure your belts are nice and tight. Sloppiness will cause waves.
[3DKarma.com] - suppliers of quality, affordable 3D printer kits and filament for the UK market.
Re: prints wavy
June 25, 2014 04:10PM
they are tight i got the wavy issue fixxed by slow it down even more but it turns out the x axis is still jumping do you know how to fix that
Re: x axis jumps
June 26, 2014 02:50PM
yes prob the amps too low on the particular motor making it loose steps
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
Re: x axis jumps
June 26, 2014 05:17PM
okay thanks for the suggestion but I have tried to turn the current up and down but it keeps on running cold
