Print Quality July 08, 2014 05:44PM |
Re: Print Quality July 13, 2014 12:27PM |
Re: Print Quality July 13, 2014 01:16PM |
Re: Print Quality July 16, 2014 10:35AM |
Re: Print Quality July 16, 2014 11:42AM |
Re: Print Quality July 17, 2014 02:02AM |
Re: Print Quality July 17, 2014 08:50AM |
Re: Print Quality July 17, 2014 11:19AM |
Re: Print Quality July 17, 2014 12:23PM |
Re: Print Quality July 17, 2014 07:32PM |
Re: Print Quality July 18, 2014 10:21PM |
Re: Print Quality July 18, 2014 11:02PM |
Re: Print Quality July 19, 2014 03:28AM |
Re: Print Quality August 17, 2014 11:10PM |
Re: Print Quality August 18, 2014 08:25AM |
Re: Print Quality August 27, 2014 04:57PM |
You may want to check that out too.Quote
A similar and probably more common error is resistance from the spool pulling against the extruder, which will tend to lift it. This is most prevalent on machines that move the extruder on the Z axis, especially if it is on a cantilevered platform like on the Thing-o-matic. In these cases, the filament will pull until there is enough tension to pull it loose, and the extruder will fall back to its normal position.
