Auto Bed Leveling with an Inductive Proximity Sensor October 18, 2014 05:24PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 18, 2014 07:26PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 18, 2014 07:28PM |
I have not measured the output. It did not change with the LED. I connected it to the endstop positive and ground pins.Quote
VDX
... several questions: - have you measured the output? - did it change with the LED or not? - which driving voltage (6-36V!) and how did you connect it to the 5V input?
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 18, 2014 09:55PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 18, 2014 09:58PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 18, 2014 11:43PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 12:07PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 12:10PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 12:54PM |
I am not testing with my heated bed, so I will cross that bridge once I get the probe to switch logic. I am testing with an aluminum build plate that works with my Printrbot probe. I already connected them like that. I have not tried using 12V though. I do not understand why I would need 12V if the Printrbot probe works on Printrboard and RAMPS with 5V, but I will try 12V as soon as I get a voltage regulator.Quote
ggherbaz
Using sensor 1 that is the correct type, connect brown to + blue to - and black to signal. Do M119 if shows triggered switch logic, do M119 and verify that is open, put a metal close to it and do M119 again should say triggered, if not, then you will have to used 12 volts and a voltage divider or LM7805 for signal to ramps.
Now this might be an stupid question: what kind of heated bed you have? Do you have enough metal there for the sensor to work properly?. I used capacitive sensors instead because they read any material and they read the top and not bottom of bed (glass), yes you need to have a table of offsets for different bed temperatures, but easy to do and to me they are more accurate.
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 12:56PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 12:57PM |
Will this work?Quote
ggherbaz
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 02:59PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 03:01PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 03:16PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 03:23PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 07:55PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 08:04PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor October 19, 2014 08:53PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor February 02, 2015 05:23AM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor February 03, 2015 03:51AM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor February 10, 2015 12:51AM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor February 10, 2015 05:12AM |
seavan
Your solution sounds very interesting. Do you deal with temperature drift in firmware or hardware? I see you also experimenting with ultrasound sensor. I could not find a link to schematics on your website. Do you mind posting a link?
Re: Auto Bed Leveling with an Inductive Proximity Sensor February 10, 2015 06:57PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor May 06, 2015 05:26AM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor May 06, 2015 03:12PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor July 12, 2016 06:10PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor July 12, 2016 07:56PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor July 18, 2016 01:01PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor July 18, 2016 01:21PM |
Re: Auto Bed Leveling with an Inductive Proximity Sensor July 18, 2016 01:49PM |
